What Is This Wallboard Building Material? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-17-2016, 09:16 AM   #1
Rewards Points: 220
What is this wallboard building material?
Hello,
I've been working on remodeling my kitchen in a building built in 1932. The back wall features a sleep porch that was enclosed in the 90's. The original masonry wall had a drywall material on it that was common, but I really know nothing about it. A pictures is below.
I noticed it sloughs off easily near the chimney, which I suspect is water getting in and weakening its grip to the brick/cinder block. I am curious, what do i need to do to put drywall back up, and provide protection from moisture? Masonry is, after all, a heavy sponge, what do i need to do to protect the finished wall material?
My original though was to put pt treated strips to isolate the wall board from the brick, but this also runs counter to having pt in a living space. ive been poking around online, but all my searches address more common issues,a and since i dont know what this stuff is i can't really tailor my search.
DIYHero is offline   Reply With Quote
Old 06-17-2016, 09:24 AM   #2
Rewards Points: 18,118
Re: What is this wallboard building material?
Pictures to blurry to tell.
It would be common to see plaster used in a house that old.
Post a picture of the outside wall in that area.
Old 06-17-2016, 09:41 AM   #3
Rewards Points: 220
Sincere apologies regarding the pictures, my camera phone has really gone down hill.
The outside wall area there is the brick chimney (which is currently interior to the building since the back porches were closed in). The material i am asking about seems to be very sandy.
Old 06-17-2016, 09:10 PM   #4
Retired Moderator
Rewards Points: 7,174
Many years back--water resistant drywall had a brown core---I think that is what you are looking at---
Old 06-17-2016, 10:02 PM   #5
Super Moderator
Gymschu's Avatar
Rewards Points: 152
It could be what Oh'mike is describing or, since it's near a chimney and appears sandy, it could be deteriorated plaster. It's not unusual for plaster to absorb moisture from condensation in the chimney and gradually crumble into sand after a long period of time.
"In the heat of battle, my father wove a tapestry of obscenity........."
Gymschu is online now   Reply With Quote
The Following User Says Thank You to Gymschu For This Useful Post:
oh'mike (06-18-2016)
Old 06-20-2016, 03:39 PM   #6
Rewards Points: 220
I think you are correct, it is indeed plaster. Now... though exposed brick is all the rage in this part of the land, i am curious how to properly build the wall back.
My concern is that since its an exterior wall, how do i account for the potential for moisture penetration?
getting a building permit after construction is done ChrisJJ General DIY Discussions 22 08-15-2012 09:18 AM
Replacing underlayment in entire house...what material to use? Dave321 Flooring 23 12-23-2011 03:38 PM
Water Fall - Black bonding material cprao Landscaping & Lawn Care 3 04-23-2011 04:06 PM
Old Building problems jake62 Building & Construction 5 08-20-2010 09:32 AM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 08:41 PM
