What Type Of Foundation For A 12x10' Outbuilding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-02-2010, 04:03 PM   #1
DIYer
Rewards Points: 93
What type of foundation for a 12x10' outbuilding
I'm planning to build a 12x10' habitable/insulated outbuilding after the rainy season and I'm thinking about foundation options.
I'm in the San Francisco Bay Area so temperatures are mild and there's no danger of frost. There are of course seismic concerns though. I am about a mile from the ocean so the water table is fairly high
Thanks in advance for your advice
dwoloz is offline   Reply With Quote
Old 10-02-2010, 05:00 PM   #2
Civil Engineer
Rewards Points: 5,246
First you need to check with the building inspector, they can discuss code compliant foundation options at length with you. In general, foundation possibilities include conventional concrete footings with a floating slab, post-tensioned concrete slab, concrete piers with grade beams, wooden foundation (may not meet code in your area), concrete block foundation (probably requires reinforcing due to seismic issues), and piling.
Foundation or Load Bearing Wall Issue? sheribaby Building & Construction 3 04-14-2010 05:07 PM
new home foundation cost wdsfr1968 Building & Construction 8 03-03-2010 10:59 AM
Round House Foundation Feasibility Mswick Building & Construction 23 02-27-2010 08:34 AM
Replacement concrete garage floor, dowelled into foundation? Niffumdutz Building & Construction 5 02-19-2010 08:31 PM
Foundation Repair Help rasilun Remodeling 1 10-15-2009 10:26 PM
