In What Situations Do You Use Self-drilling Or Self-tapping Screws? - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By chandler48
  • 1 Post By Marson
Old 01-05-2019, 04:24 PM   #1
Rewards Points: 54
In what situations do you use self-drilling or self-tapping screws?
farmerjohn1324 is online now   Reply With Quote
Old 01-05-2019, 05:06 PM   #2
JUSTA MEMBER
Rewards Points: 2,420
Re: In what situations do you use self-drilling or self-tapping screws?
To join 2 sheets of metal, like a furnace duct.
Or to attach something to a metal plate, or erecting metal stud walls.
Anything like that, they are useful.
ED
de-nagorg is offline   Reply With Quote
Old 01-05-2019, 05:08 PM   #3
Rewards Points: 54
ED
What about screwing plywood to subfloor?
Old 01-05-2019, 05:08 PM   #4
Naildriver
chandler48's Avatar
Rewards Points: 2,352
Well most self drilling screws are self tapping once the bit gets through the metal. It's not tapped like a tapered tap would do, but it works.
Caught your last post after posting this. No, no self drilling screws. Use deck screws for that. In addition put your screws to intentionally miss your joists.
de-nagorg likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 01-05-2019, 10:43 PM   #5
JUSTA MEMBER
Will not work, the cuttings need a place to go, and with the screw threads in the way, you won't get any hold.
ED
Old 01-06-2019, 09:26 AM   #6
Rewards Points: 926
There are self drilling wood screws. Maybe that's what he's talking about? I use them everywhere I would use a nail.
https://www.grkfasteners.com/product...e/multipurpose
Marson is offline   Reply With Quote
Old 01-06-2019, 09:42 AM   #7
Rewards Points: 54
I'll be using a collated screw gun. Apparently, the screws are a little sharper than average so they don't need pilot holes.
Old 01-06-2019, 09:55 AM   #8
Rewards Points: 17,812
Screwing down a subfloor would be the slowest and most expencive way to do it, it will leave a hump, and will tend to want to lift the subfloor as it makes contact with the second piece before grabbing.
8D ringed shanked nails in a nail gun would be 100 times faster and there near impossible to pull out.
Screws / bolts securing brake rotors / drums WyrTwister Automotive Repairs 9 11-05-2015 09:59 AM
are deck screws enough to stop a kick in? Tonglebeak Carpentry 18 12-10-2011 08:19 PM
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 07:08 AM
Refinishing / Repairing Deck: Screws vs. Nails? superhandymom Building & Construction 1 05-10-2010 02:08 AM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 05:58 AM
