What Should I Put On Here Siding Or Sheetrock? - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree15Likes
Old 09-06-2018, 05:59 PM   #1
Endless Projects
Rewards Points: 1,184
What should I put on here siding or sheetrock?
I have removed the siding that was up in order to build my extension. I now a tyvek ed wall inside my extension. I am going to build a 10 foot set of shelves and store bikes rakes and other things along this wall. I was tempted to just leave it as Tyvek but what other options do I have for this wall?
Photobug is offline   Reply With Quote
Old 09-06-2018, 06:04 PM   #2
Property Mgt/Maint
Rewards Points: 6,232
Re: What should I put on here siding or sheetrock?
Whats behind the Tyvek?
Nealtw likes this.
Yodaman is offline   Reply With Quote
Old 09-06-2018, 06:25 PM   #3
Endless Projects
My garage wall exterior: first sheeting, insulated 2x6 wall then sheetrock.
I don't plan on finishing the rest of the shed so was going to leave this with just Tyvek but now I am figuring just a simple 1/2" sheetrock for the wall. A quick tape job and paint that way when I install some lights in there the white wall will make it look brighter.
Old 09-06-2018, 06:31 PM   #4
retired framer
Rewards Points: 13,968
The sheeting is all you need after that it doesn't much matter.
For brighter I would just spray everything white.
Old 09-06-2018, 06:35 PM   #5
Endless Projects
Are you saying just spray the tyvek white? If so I am down with that.
Old 09-06-2018, 06:37 PM   #6
Rewards Points: 1,502
Put up some plywood.. then u can hang whatever you want from wherever you want...
ryansdiydad is offline   Reply With Quote
Old 09-06-2018, 06:38 PM   #7
retired framer
Tyvec is all about rain, I would take it down. It will just look ratty after a couple years of abuse.
Old 09-06-2018, 07:01 PM   #8
Endless Projects
Got it take down the Tyvek, and spray paint it.
Old 09-06-2018, 07:03 PM   #9
Endless Projects
I already got plywood with the sheeting.
Old 09-06-2018, 07:10 PM   #10
Super Moderator
joed's Avatar
Rewards Points: 22,638
I would remove the tyvek and expose the plywood sheeting
de-nagorg and romeojk27 like this.
Old 09-06-2018, 08:02 PM   #11
Endless Projects
That's the plan, can't remember, hoping it is CDx not OSB.
Old 09-07-2018, 05:18 AM   #12
retired painter
Rewards Points: 498
You can still paint OSB but some of the chips from the different species can discolor the paint unless you use an oil base primer.
mark sr is offline   Reply With Quote
Old 09-07-2018, 06:31 AM   #13
Rewards Points: 3,836
I would make sure to close up that hole in the corner and any other hole that allows daylight in.
Oh yeah.
https://www.familyhandyman.com/garage/storage/
Photobug likes this.
ron45 is offline   Reply With Quote
Old 09-07-2018, 10:22 AM   #14
Endless Projects
Just remembered the sheething is CDX
Oh yeah.
It will all be well enclosed. I will hopefully have crew show up this weekend to help raise beam, and hang 6 more rafters and finish sheething the roof. With an inspection either this evening or Monday morning.
Old 09-07-2018, 10:26 AM   #15
Endless Projects
Oh yeah.
When it is done I will share the results. It will not look like anything that could be published in family handyman but it will hold a lot of tools toys and others. It is way overbuilt and I am ready to be finished so I can start populating it.
ron45 likes this.
broken lower siding fix/solution ? tstex Roofing/Siding 12 08-04-2017 05:54 PM
Siding right on studs? Davef_dci Carpentry 6 03-07-2013 05:31 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
