What Material Can Support This? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-21-2010, 09:23 AM   #1
Rewards Points: 260
What material can support this?
This is for a temporary 10x10 canopy. I need to hang a 30lb object in the center of it. I was thinking about running a 10 ft slotted unistrut (Channel). Do you think it would bow in the center? What size unistrut should I buy to support this? I could also do a cross configuration using two pieces. If you have suggestions on different material, let me know.
Thanks in advance
bluefitness is offline   Reply With Quote
Basement Metal Support Post virgolibranyc Building & Construction 4 09-07-2010 03:07 PM
moving a support wall 6 ft over.? help jstamps Building & Construction 1 04-20-2010 05:48 AM
Temporarily remove basement support post ColinD Building & Construction 14 12-04-2008 05:07 PM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 07:41 PM
