What To Get For Bridging 2x6 24" Oc? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-25-2010, 05:15 PM   #16
Old School
Willie T's Avatar
I would get everything back to level, and supported the way you want it prior to installing the bridging.
Willie T
Old 01-25-2010, 05:39 PM   #17
Wildie: Even though I'll be using glue as well?
Willie: I understand the reasoning for dealing with the first floor first, but is it absolutely required? Just wondering.
Tonglebeak is offline   Reply With Quote
Old 01-26-2010, 04:53 PM   #18
Glue and screws will be very solid. Using nails causes a lot trauma in the area to be nailed and is more likely to split the bridging when they are pounded in.
24" O.C. with tile? jackie treehorn Kitchen & Bath Remodeling 9 01-01-2010 04:38 PM
tile saw advice for 24" porcelain tiles diy'er on LI Tiling, ceramics, marble 12 10-11-2009 03:34 PM
Replacing wood on 24" center trusses Novar Roofing/Siding 2 04-24-2009 07:24 PM
24" conduit rule derrating does not apply jamiedolan Electrical 10 02-27-2009 09:26 AM
