What Does The Rectangle Under The Head Of Carriage Bolt Do? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-13-2009, 12:18 PM   #1
What does the rectangle under the head of carriage bolt do?
Anyone know? You have the head of the bolt and then a rectangle under it followed by the threads
gomerpyle is offline   Reply With Quote
Old 06-13-2009, 12:32 PM   #2
Rewards Points: 5,348
Post deleted.
Old 06-13-2009, 01:09 PM   #3
Usually this fits into a square slot that prevents the bolt from turning
Old 06-13-2009, 03:30 PM   #4
Aw Yeah,like Scuba Dave said. Carriage bolts are used where you cant( or can't easily) get a tool on the back side of the fastener to hold against your tightening of the nut. The "rectangle" in the slot does the holding that would normally be done by wrench or pliers.
white29 is offline   Reply With Quote
Old 06-13-2009, 03:32 PM   #5
Oh Yeah. Really it's a square,no?
Old 06-13-2009, 07:35 PM   #6
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
in wood applications, they are usually used in a tight tolerence round hole. as you tighten the nut, the square portion embeds itself into the wood, keeping the head end from spinning. They also sell special washers the have a square cut out and "teeth" on the outer edges ( like a t-nut). You hammer the washer over a hole, and the square shoulder sits in the square cut inner hole.
Mr Chips is offline   Reply With Quote
Old 06-13-2009, 07:41 PM   #7
Yup, I used those washers when I built my 8' picanic table
Clipped Head v. Full Round Head Nails RickT Carpentry 10 11-18-2010 09:00 AM
Shower Head Breaking Off mbarnes Plumbing 3 01-11-2009 06:38 PM
Weird shower head leaking problem shawnst Plumbing 5 12-25-2008 11:23 AM
Weak stream of water from shower head. SuperAkuma Plumbing 3 08-01-2008 05:49 PM
Attach a bolt to drywall hdayanan Building & Construction 1 03-17-2006 07:01 AM
