What Do You Call This Bracket? - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By de-nagorg
Old 02-23-2018, 06:07 PM   #1
Rewards Points: 24
Not sure what this type of bracket is called. It's designed to be weight bearing and held in place by gravity, but so the upper piece can easily be removed when needed by lifting up. Thanks!
sub780lime is offline   Reply With Quote
Old 02-23-2018, 06:18 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 4,342
Re: What Do You Call This Bracket?
Where is it located in this picture? Shower, kitchen, garage? Is the picture upright or do we need to stand on our heads or twist sideways?
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 02-24-2018, 10:13 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,492
Ayuh,.... Agreed,... Really poor picture, Especially with no background info,...
Old 02-24-2018, 10:24 AM   #4
Rewards Points: 24
Sorry for the lack of details. The picture is right side up and this was the only picture I found of it. I'll see if I can dig up another. It is a piece of furniture, so what's at the top of the photo is a platform, think a table top, while the light wood piece is a support beam that would run to the ground as a table leg. The green round piece is affixed to the light wood leg, while the black bracket is connected to the table top. Essentially, it connects the too but allows you to just lift the table top off the legs when needed without undoing anything. I hope all that helps .
Old 02-24-2018, 10:54 AM   #5
JUSTA MEMBER
Probably a specialty piece, made exclusively by the furniture maker for this purpose.
Many furniture makers have their own engineering staff, that make their own types of fasteners, brackets, flanges, and other hardware.
ED
lenaitch and Nealtw like this.
de-nagorg is offline   Reply With Quote
Light Fixture Bracket Thisiseasy Electrical 4 08-03-2017 12:34 PM
Hanging a new ceiling fan with no bracket? helpme81 Electrical 9 07-10-2017 05:03 PM
ceiling fan mounting bracket CNT Electrical 15 04-01-2017 11:08 PM
clg fan install bracket gt1935 Electrical 2 03-28-2016 03:30 PM
How to extend a metal bracket? CubsWin Metal Fabrication 10 06-06-2015 06:22 AM
