What To Do With Roof Line - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-10-2010, 10:09 AM   #16
i wouldn't worry about the lack of ridge beam.
how big are the existing rafters? if they're only 2X4 or 2X6, considering either sistering on the next bigger dimension along the slope that will carry the new shed roof, or doubling up what's there.
wombosi is offline   Reply With Quote
Old 09-10-2010, 11:58 AM   #17
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,371
I'm getting bad at this, I just said the same thing you already said. Sorry
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 09-10-2010, 12:16 PM   #18
Chicago, IL
Michael Thomas's Avatar
The typical detail at that type of junction is a double ended cricket:
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 09-10-2010, 12:51 PM   #19
Correct, like you would put behind a chimney. Since the roof that is there is in terrible shape after years of water sitting in that valley eating away at the shingles and subsequently the sheathing underneath. At this point I need to do it correctly.
Justin08 is offline   Reply With Quote
Flat roof repair/replacement questions zmt Roofing/Siding 4 02-23-2010 11:24 AM
Blown Insulation - Flat roof AndrewF Roofing/Siding 1 12-31-2009 06:41 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
gas line penetration of torch down roof bpiper Roofing/Siding 3 01-11-2008 10:19 PM
