What Adhesive To Use For Attaching Limestone To Drywall On A Vertical Surface - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-24-2010, 02:02 AM   #1
JP1
What adhesive to use for attaching limestone to drywall on a vertical surface
I am in the process for remodeling my wood burning fireplace at home. I have purchased limestone for the project, and have custom cut and polished pieces for the job. These pieces (2 legs, 1 header, and 1 riser) will be set in place around the (E) metal firebox flush to the wall. The company that I have purchased the mantel from (but not the limestone) called Mantels Direct recommends Leech F26 heavy duty construction adhesive for attaching the limestone to the vertical drywall surface. The only problem is, they don't sell this product in California where I live.
Please advise what other adhesive I can use that is similar to Leech F26 that will get the job done. I went to Home Depot, and the closest thing I could find to the Leech product was Loctite PL375 heavy duty construction adhesive.
Thanks!
JP1 is offline   Reply With Quote
Old 07-24-2010, 02:07 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Q. Where can I buy Leech adhesives?
A. You can become a distributor or dealer of our products by contacting us. If you are a contractor or consumer, you can email us or call us for the retailer nearest you.
Leech Products 800-992-9018
PO Box 2147 Hutchinson, KS 67504
620-669-0145 fax 620-669-1183
http://www.google.com/search?hl=en&s...=&oq=&gs_rfai=
Drywall - Horizontal or vertical slinku2020 Drywall & Plaster 27 04-08-2010 12:40 PM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
Smoothing out a painted and not painted drywall surface MarksHouse Drywall & Plaster 5 10-21-2008 11:50 AM
Installing handrails on drywall surface n0c7 Drywall & Plaster 5 09-13-2008 01:17 PM
installing drywall to 10 ft vertical walls markt59 Building & Construction 6 01-16-2008 07:09 PM
