Weird Wall Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-29-2014, 01:20 AM   #1
Rewards Points: 978
Question
weird wall question
hi guys
so i am framing out a semi closet space. the studs are in place, but instead of drywall or plywood, what's another good material i can use for walls? the reason being i want something super light weight. this is in a tiny closet space about 4ft by 4. it needs to be about 1in thick
i was thinking like a rigid foam board. would that work? aesthetics isnt a big issue
federer is offline   Reply With Quote
Old 10-29-2014, 02:07 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 17,646
Aesthetics is not your issue. Foam would be destroyed in no time.
Why not Drywall? It's only 1/2" thick.
Why are you worried about weight?
Old 10-29-2014, 02:58 AM   #3
Rewards Points: 978
ItCan't Stand In It So I Won't Destroy It. NeedsToBe 1In thick
Old 10-29-2014, 08:05 AM   #4
Rewards Points: 526
Attaching 3/4 cleats then 1/4 panels? Would be cheaper.
carpdad is offline   Reply With Quote
The Following User Says Thank You to carpdad For This Useful Post:
federer (10-29-2014)
Old 10-29-2014, 08:38 AM   #5
Low Slope Roofing
Rewards Points: 114
You could use XPS insulation, it's stiffer then EPS and doesn't have fiberglass like ISO, you would need some wide plates to attach it as regular screws with no plates will not hold it. This will be ugly as a finish. Another thing you could do would be use 3/4" EPS or XPS and 1/4" paneling. Still light weight, still 1" and will look a lot better. Even though aesthetics are not an issue after a while I would be asking my self why I did that.
1985gt is offline   Reply With Quote
The Following User Says Thank You to 1985gt For This Useful Post:
Old 10-29-2014, 09:30 AM   #6
Rewards Points: 18,376
Foam can not be left exposed, Why not just use paneling?
Old 10-29-2014, 09:58 AM   #7
Rewards Points: 298
Federer,I'm a beginner too,but I have framed a few interior walls. I can't understand your 1" requirement?
flhtcu is offline   Reply With Quote
Old 10-29-2014, 10:00 AM   #8
Rewards Points: 80
Hard board or MDF. Hardboard comes in various thickness and is pretty strong. You can get it 1/4" thick or 1" thick. But 1" thick is probably heavier than Gypsum Board.
Gyp. bd (drywall) is probably the cheapest lightest option that will be able to last.
There are some corrugated plastics that are lighter that are an inch thick, but they are somewhat translucent.
Koolhaas is offline   Reply With Quote
The Following User Says Thank You to Koolhaas For This Useful Post:
Old 10-29-2014, 02:17 PM   #9
Rewards Points: 978
good idea! cheaper and light
Old 10-29-2014, 02:20 PM   #10
Rewards Points: 978
thank you for the input everyone.
i will be using some kind of paneling over the foam/etc to hide it. it needs 1 inch because its a closet that was badly framed out.
joe why cant foam be exposed?
i didnt want to go mdf route. and it doesnt come in 1in thickness.
yea the XPS with panel was my first thought
Old 10-29-2014, 09:45 PM   #11
Msradell's Avatar
Rewards Points: 976
The foam cannot be left exposed because it's a fire code issue.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
The Following User Says Thank You to Msradell For This Useful Post:
Old 10-29-2014, 09:47 PM   #12
Rewards Points: 978
ah gotcha. thank you. i plan on putting wallpaper over it
Old 10-29-2014, 09:51 PM   #13
Rewards Points: 978
so to give you guys better idea this is what i am talking about.
the closet is sort of built into the wall under the roof/rafters
nothing is square, hence needing all the furring out. because its such a tiny space i decided i didnt want to add more weight with drywall/plywood. i am just going to store misc items in there sort of like a storage space.
weird wall question-img_20141027_183347_078.jpg   weird wall question-img_20141027_183404_722.jpg
Courtyard wall - subbase question Pbody Landscaping & Lawn Care 3 02-27-2012 01:39 PM
Open Web Truss/ Load Bearing Wall Question rlc2052 Flooring 3 03-05-2010 10:37 AM
Question about removing trim wall in foyer cary00silve Remodeling 1 02-02-2010 01:02 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 06:39 PM
Garage wall construction question Bjonas Building & Construction 4 01-01-2008 05:18 PM
