Weight Load - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-31-2010, 01:36 PM   #1
Weight load
I have an attic with 2x6 24" on center joists and 3/4" plywood flooring. How much weight can this floor hold?
Iwilldoit is offline   Reply With Quote
Old 12-31-2010, 01:39 PM   #2
Framing Contractor
Why do you want to know? What are you planning on doing?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 12-31-2010, 01:52 PM   #3
Hobby
I want to set up a sewing room with two mdf cabinets/work table and an antique oak map chest for fabric storage
Old 12-31-2010, 01:56 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 224
Ayuh,... That doesn't sound like a Heavy hobby,...
I'd go for it....
Old 12-31-2010, 02:01 PM   #5
concretemasonry's Avatar
Rewards Points: 2,716
It would also nice to know the span of the joists, but that could be considered a living area and those loads would apply.
Dick
concretemasonry is offline   Reply With Quote
Old 12-31-2010, 02:04 PM   #6
Span
The house is 30' but there are center stairs running at a right angle to the run of the joists and also there are supporting walls below for the bed and bath walls. The longest unsupported span is 13'
Old 12-31-2010, 03:15 PM   #7
Framing Contractor
I want to set up a sewing room.
2x6 @ 24 " center cannot span 13' for a floor. Don't listen to anyone who tells you to go for it. Your using it as a room with a floor load. This is designed as a 2x6 ceiling and not designed for a floor and room.
Joe Carola
Old 12-31-2010, 03:21 PM   #8
Weight load
Thanks Joe. I really don't want to find myself sitting with my sewing cabinet in the bedroom below without using the stairs! I just hate not being able to use that space for more than storing Christmas decorations. Rats!
Old 12-31-2010, 03:26 PM   #9
Bondo's Avatar
Rewards Points: 224
Ayuh,... That'll Never happen...
At Worst, the ceiling below might Sag, if you put too much junk up there....
Old 12-31-2010, 03:45 PM   #10
I've seen some REALLY heavy sewing machines
A 2x6 24" OC will span close to 9' @ L360 depending upon the species of wood & grade etc
Old 12-31-2010, 07:51 PM   #11
Registered User
Rewards Points: 526
You will need a permit for the attic conversion, the good news-- floor rated at only 30#l.l. for attic rooms in 2009; http://docs.google.com/viewer?a=v&q=...1txlzU01V4JQIg
The bad news--- you would be over-spanned at 13'; http://www.awc.org/calculators/span/...al+Span#answer
as mentioned.
Gary
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 05:33 PM
Floor Weight Load RalphPeters Flooring 0 02-08-2010 02:16 PM
How much load weight can a 4x4x14 redwood beam bear lawdealer Carpentry 6 10-09-2009 11:00 AM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 08:37 AM
beam support cibula11 Building & Construction 20 02-16-2007 09:02 AM
