Weathered Plywood - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-13-2014, 05:30 PM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,896
weathered plywood
Building a roof over my new deck.
While I was framing the roof I through down some plywood to work off of and use as temporary decking.
That was about 7-8 weeks ago. Now I'm down to needing the last two sheets and wondering if this plywood is still usable. It has a mostly gray color to it now on one side. Would ~2 months of rain and sun degrade the plywood enough so that it cannot be used?
TIA
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 10-13-2014, 08:20 PM   #2
I have gas!
It looks like it is definitely usable... I came across this:
Plywood exposed for more than 21 yr to continuous weathering and use as the roof decking of portable hog houses was found to have strength properties comparable to those expected in new plywood. Tests of 10 panels in flexure, rolling shear, and shear-through-the-thickness, conducted according to ASTM standards, showed the weathered plywood to have structural properties sufficient to justify use of the currently published design stresses. Comparison of bending properties of specimens with weathered face ply intact with specimens in which the weathered face ply had been removed suggested no significant degradation due to weathering.
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-13-2010 11:09 PM
It is hard to find 1/2 t and G plywood so would regular plywood be ok ? dewi Flooring 14 05-04-2010 12:05 PM
Tile over plywood? Thurman Flooring 3 07-12-2009 09:05 AM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 07:06 PM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 12:11 PM
