Walls To Tall - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Like Tree7Likes
Old 01-22-2019, 09:05 AM   #31
Rewards Points: 178
Re: Walls to tall
Originally Posted by ClarenceBauer View Post
Maybe you need to think about switching to metal studs cut to your required lengths & order 54 inch wide Gypsum Board. Use fire rated deflection track @ the top & cold rolled channel for bridging.
Length of studs is not my main concern. I could return my pre cuts and get longer lumber (more $$)
Bryan n Deb is offline   Reply With Quote
Old 01-22-2019, 10:14 AM   #32
Rewards Points: 170
Re: Walls to tall
its 1.5", just add another plate and you'll be fine with teh lumber you have.
For the sheetrock, just cut a strip 1.5" out of 3/8 rock, put it in the middle of the wall and it will meet with the tapers.
tuffy1965 likes this.
Spyder is online now   Reply With Quote
Old 01-22-2019, 04:50 PM   #33
Contractor/Engineer
Rewards Points: 1,138
Re: Walls to tall
Wouldnt you have to put nailers up on at least 4' centers all across the rooms?
Frame the interior walls 9' tall and (as always) cap them with a 2x6 or other scrap that overextends to provide a nailer for the ceiling sheetrock.
The nailer/backer I referenced would only go on the perimeter frame members that are 1-1/2" too high.
What you described will actually work out fine. The sheetrock needs backing so you can hang it to the ceiling. Therefore, all the walls seems correct - just too bad they didn't use 2x6 as an upper plate on the outside walls - if they had, you're nailers for the ceiling would already be in place and you wouldn't be confused by the difference in height.
If you don't put the nailers in, what do you nail the ceiling to if its a pole barn without trusses (which is what I'm understanding).
It's just wood - it's easy...
Domo is offline   Reply With Quote
Old 01-22-2019, 06:19 PM   #34
Framing Contractor
Rewards Points: 70
Re: Walls to tall
Your framers used precut studs, which is likely what the print called for. If the ceiling was framed to exactly 9', every bottom board of drywall would need cut. 5/8 is usually put on ceilings where trusses are 24" o.c.
sixeightten is offline   Reply With Quote
Old 01-22-2019, 07:52 PM   #35
Rewards Points: 1,272
Re: Walls to tall
Go with Neal's plywood idea then you can shoot that trim "anywhere" instead of having to hit the studs
195795 is offline   Reply With Quote
Floating Basement Walls jonhayden Building & Construction 15 12-16-2013 09:53 PM
2x4 cabin, what can these walls handle? Ilyae Building & Construction 8 04-08-2013 12:02 PM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 01:07 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 06:59 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 09:17 AM
