Walls To Tall - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree7Likes
Old 01-21-2019, 09:37 PM   #16
Rewards Points: 4,700
Re: Walls to tall
If the floor to ceiling without drywall is 9' 1.5" you are not that far off. Ceiling drywall goes up first so that takes up 1/2". Then you don't set the drywall on the floor, up 1/2" would be common. That leaves the bottom of your drywall still backed by 1/2" of bottom plate.
If you don't like the gap, install a piece of something to fill it after the drywall is up.
Bud
Bryan n Deb likes this.
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 01-21-2019, 09:37 PM   #17
Rewards Points: 152
Re: Walls to tall
Originally Posted by Nealtw View Post
Inspector don't like the 3rd on top but the extra one on the bottom never seems to raise eyebrows.
Only planned on 1 top and 1 bottom. I pretty much have to add to the bottom or there will be no place to attach the bottom of the sheetrock.
Bryan n Deb is offline   Reply With Quote
Old 01-21-2019, 09:38 PM   #18
Two Knots's Avatar
Rewards Points: 3,267
Re: Walls to tall
Originally Posted by Bryan n Deb View Post
Right, and nobody will know about the 1.5 inches. As stated above I will have about 1.5 inches not covered by sheetrock at the bottom of the wall.
I would say that the builder has to add a 1 1/2 strip of Sheetrock
and sparkle and tape as well. Seems to me its his problem, not yours.
This will be covered with floor molding anyhow.
Behind every clever man is an astonished woman!
*Joann*
Dogs love me, men fear me!
Two Knots is offline   Reply With Quote
Old 01-21-2019, 09:42 PM   #19
Rewards Points: 152
Re: Walls to tall
I am the builder, I hired a crew to put up a shell. My problem.
Old 01-21-2019, 09:46 PM   #20
Two Knots's Avatar
Re: Walls to tall
Oh, no matter, you still need to Sheetrock, tape and sparkle the bottom
before adding the molding.
*Joann*
Old 01-21-2019, 09:49 PM   #21
retired framer
Rewards Points: 13,968
Re: Walls to tall
OK, confused me, the normal is 2 plates on top
and you have 104 1/4 + 4 1/2 wall at 108 3/4 in Canada
or 104 5/8 + 4 1/2 wall is 109 1/8
5/8 ceiling goes up first leaving 1/4" in Canada. and nothing in the US
Old 01-21-2019, 10:00 PM   #22
Rewards Points: 152
Re: Walls to tall
I could be wrong but because the walls are not supporting anything I only need one top plate. Also doing 1/2 ceiling rock. I could do 5/8 I guess but an eighth wont make or break this.
Old 01-21-2019, 10:16 PM   #23
retired framer
Re: Walls to tall
You want to top plates so the top plate can be lapped where they meet and lock together, You are not supposed to nail them to the trusses just some little clips, the walls need all the help they can get.
All lumber has a crown or bend to it so the top 2 plates are crown opposite to each other and straightened with sucker nails to make the wall straight.
fire rated dry wall should be in your code and it is 5/8 for ceilings
Old 01-21-2019, 10:25 PM   #24
retired framer
Re: Walls to tall
We only do two top plates in basement when we need them for height because everything can be nailed solid to the joists above. We are taking about years of fixing cracks and looking a warped walls. What you need and what you want are two different things.
Old 01-21-2019, 10:33 PM   #25
Rewards Points: 152
Re: Walls to tall
My inlaws just had a house built and 5/8 rock was on the print. Found out later 1/2 was used but building inspector says its fine. Ill make a phone call on that one.
Nealtw likes this.
Old 01-22-2019, 12:37 AM   #26
Rewards Points: 2,546
Re: Walls to tall
Just use 10' sheetrock cut to size.
LawnGuyLandSparky is offline   Reply With Quote
Old 01-22-2019, 12:47 AM   #27
Contractor/Engineer
Rewards Points: 1,078
Re: Walls to tall
Nail a 1-1/2" nailer for the ceiling sheetrock around the entire perimeter - you need something to nail to anyway. Then frame to 9' for all interior walls.
No big deal - that's the type of task that goes to the new guy. Better yet - have that framing crew do it on their dime.
Domo is offline   Reply With Quote
Old 01-22-2019, 06:08 AM   #28
Rewards Points: 152
Re: Walls to tall
Thought about that but then id have a vertical seam floor to ceiling every 4 feet.
Id rather lay it down and have 1 seam all the way around the room.
Old 01-22-2019, 06:10 AM   #29
Rewards Points: 152
Re: Walls to tall
Wouldnt you have to put nailers up on at least 4' centers all across the rooms?
Old 01-22-2019, 06:57 AM   #30
Rewards Points: 2,652
Re: Walls to tall
Maybe you need to think about switching to metal studs cut to your required lengths & order 54 inch wide Gypsum Board. Use fire rated deflection track @ the top & cold rolled channel for bridging.
ClarenceBauer is offline   Reply With Quote
Floating Basement Walls jonhayden Building & Construction 15 12-16-2013 08:53 PM
2x4 cabin, what can these walls handle? Ilyae Building & Construction 8 04-08-2013 11:02 AM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 12:07 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
