DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Building & Construction (https://www.diychatroom.com/f19/)
-   -   Walls to tall (https://www.diychatroom.com/f19/walls-tall-651549/)
Bryan n Deb 01-22-2019 09:05 AM
Re: Walls to tall
Originally Posted by ClarenceBauer (Post 5747361)
Maybe you need to think about switching to metal studs cut to your required lengths & order 54 inch wide Gypsum Board. Use fire rated deflection track @ the top & cold rolled channel for bridging.
Length of studs is not my main concern. I could return my pre cuts and get longer lumber (more $$)
Spyder 01-22-2019 10:14 AM
Re: Walls to tall
its 1.5", just add another plate and you'll be fine with teh lumber you have.
For the sheetrock, just cut a strip 1.5" out of 3/8 rock, put it in the middle of the wall and it will meet with the tapers.
Domo 01-22-2019 04:50 PM
Re: Walls to tall
Originally Posted by Bryan n Deb (Post 5747329)
Wouldnt you have to put nailers up on at least 4' centers all across the rooms?
Frame the interior walls 9' tall and (as always) cap them with a 2x6 or other scrap that overextends to provide a nailer for the ceiling sheetrock.
The nailer/backer I referenced would only go on the perimeter frame members that are 1-1/2" too high.
What you described will actually work out fine. The sheetrock needs backing so you can hang it to the ceiling. Therefore, all the walls seems correct - just too bad they didn't use 2x6 as an upper plate on the outside walls - if they had, you're nailers for the ceiling would already be in place and you wouldn't be confused by the difference in height.
If you don't put the nailers in, what do you nail the ceiling to if its a pole barn without trusses (which is what I'm understanding).
It's just wood - it's easy...
sixeightten 01-22-2019 06:19 PM
Re: Walls to tall
Your framers used precut studs, which is likely what the print called for. If the ceiling was framed to exactly 9', every bottom board of drywall would need cut. 5/8 is usually put on ceilings where trusses are 24" o.c.
195795 01-22-2019 07:52 PM
Re: Walls to tall
Go with Neal's plywood idea then you can shoot that trim "anywhere" instead of having to hit the studs
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
