Wall Ties Rusting - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-02-2010, 09:16 PM   #1
Rewards Points: 95
Wall Ties rusting
Hi,
In my basement I had three wall ties with leaks around them which have been fixed by the builder (now he is out of business).
That got me wondering if I should rustoleum ALL the wall ties that are exposed on the inside, and then epoxy them up?
The thought process is, the wall tie is metal extending thru the poured concrete, so as that rusts it will create a void allowing water to come thru.
The rustoleum may help retard the rusting, and then if I epoxy over them, if they eventually rust, they rust.
Thoughts??
Thanks in advance.
bergerdude is offline   Reply With Quote
Old 03-03-2010, 08:19 AM   #2
Rewards Points: 5,348
Therse will continue to rust in the wall no matter what you do to the surface exposure. I doubt anything you do will last too long as this rust will come from behind and under any covering material.
There's not a whole lot of expensive materials going into this, so give it a shot and see what happens.
Ron
securring an existing railroad tie retaining wall secondguesser Landscaping & Lawn Care 1 07-02-2009 08:52 PM
Loads on a partition wall acyate Building & Construction 8 02-28-2009 11:02 PM
New opening in a brick veneer wall - installing new brick ties? GrantJohnson Building & Construction 3 01-28-2009 10:17 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
