Wall Resurfacing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-12-2010, 05:18 AM   #1
dra
wall resurfacing
Hi- I have the following situation: I had some foundation problems following the construction of an addition to an older house (essentially the addition tilted away from the original structure, leaving a large vertical crack and some damage due to a bowed wall etc.). Anyway, the foundation has been piered and is now sound (ho, ho...), but the concrete wall remains cosmetically unattractive (mainly un-eveness around the area where it joins the main house). I'd like to resurface the whole wall. Any tips/ideas? Would a really thick stucco paint do the job?
dra is offline   Reply With Quote
Old 10-12-2010, 08:22 AM   #2
Rewards Points: 2,826
1st, the crack should never be sealed w/anything but a flexible joint sealant applied over closed cell backer rod,,, if the wall's ugly, it can be resurfaced after any repairs such as grinding down high spots,,, we use polymer-modified resurfacing bag mix avail at any const supply house ( NOT an apron store ),,, wse'll use mechanically attached expanded wire mesh al a stucco or apply straight onto the properly prep'd conc - flat, vertical, & ovhd mortars are avail,,, you can ' build ' the repair up to 2",,, for more, do it in lifts,,, good luck !
stadry is online now   Reply With Quote
Cutting through masonry wall mwpiper Remodeling 4 04-17-2010 11:30 AM
building a wall against an exterior wall Mike L General DIY Discussions 2 08-20-2009 03:50 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 04:29 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
