Is This Wall Load Bearing - Pictures Attached - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-31-2010, 03:42 PM   #16
Rewards Points: 5,348
Originally Posted by jen5219 View Post
Thanks. I've read in flooring that you could, but will investigate somemore. Thanks. My heart is very sad if this is true.!!!! I posted something on the flooring sections. No replies yet, maybe no one wants to tell me the bad news?
It can be done( as per Schulter) if the joists are the correct size, the space between them is appropriate, the span isn't too long, the subflooring flooring is plywood(glued and screwed) and covered by something like Schulter Ditra.
Personally, I like 2 layers of ply, glued and screwed with a layer of cement board, thinsetted and screwed.
I'm a romantic.
Ron
Old 08-01-2010, 12:17 PM   #17
Thanks for all your help!!!! Enjoy.
Jen.
jen5219 is offline   Reply With Quote
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 04:33 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
Load bearing Wall? flyndave2002 Building & Construction 19 02-22-2008 11:24 AM
load bearing wall no more grant Building & Construction 5 10-14-2007 08:50 PM
Load Bearing Wall or not?? dtmbizzle Building & Construction 3 07-16-2007 07:12 AM
