Wall Creaking Popping When Walking On Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-01-2017, 10:46 AM   #1
Wall Creaking Popping when walking on Floor
Our house was built in 1988 and we have a rlly bad creak and pop under hallway wall that connects to our baby's room I'm trying to fix I originally used breakaway screws through carpets into joists but didn't help with this area when stepping in the room or hall there's loud creaking popping but it's coming from wall area wondering best ways to fix this without tearing up the sheetrock and trim I've read it could be the wood has dried and nails are rubbing when wall and floor flexes I've also read to try putting screws from floor sheathing to sill plate just don't know how to do that sorry new to this stuff any help advice is greatly appreciated I can access all joists and subfloor from below in garage
JAAWAR is offline   Reply With Quote
Old 10-01-2017, 11:34 AM   #2
Rewards Points: 84
Re: Wall Creaking Popping when walking on Floor
Have you tried having someone in the garage area while someone walks around the hallway area, to try and narrow down the noise area?
Also if you can see the floor joists of your living area from the garage area, you will need to ensure there is no air entering the living area from the garage and then you will need a fire guard installed between the two areas.
daveb1 is online now   Reply With Quote
2nd floor deck rotted out load bearing wall RobV4397 Building & Construction 4 02-25-2018 04:38 PM
Stone house wall insulation Huckleberry17 Insulation 17 10-19-2017 09:11 PM
Filling gap between basement foundation wall and floor - material recommendations robbrown99 Concrete, Stone & Masonry 9 07-05-2017 10:59 PM
Load Bearing Wall Holding up Second Story on Floor Joists HDS Building & Construction 13 10-31-2014 04:33 PM
JAcking up floor to replace bottom wall plate. tpicklesimer Flooring 0 05-24-2011 08:08 AM
