Wall Construction - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-10-2011, 05:17 PM   #1
Wall Construction
Can I build walls by stacking 2x4's on top of each other, thereby eliminating the need for insulation?
jparker49 is offline   Reply With Quote
Old 02-10-2011, 05:19 PM   #2
Love for Construction
<*(((><'s Avatar
No.
2x4's add very little insulating value. Not to mention you would be using a lot of lumber to build a wall that way.
-luke-
<*(((>< is offline   Reply With Quote
Old 02-10-2011, 05:21 PM   #3
Experienced
Jackofall1's Avatar
Rewards Points: 2,108
Seriously? how would you ever accomplish that, the R value would be like 4 and cost would be out of this world, even if it was possible.
Old 02-10-2011, 07:20 PM   #4
Carpenter
dtsman's Avatar
As I see it, you are creating a log cabin. Instead of logs you are using 2x4s. Wood has no R value. Well, it probably does, but not worth measuring.
So the answer to elimanating insulation is no. There is no insulation value.
Bo
Remember,
If the women don't find you handsome,
they should at least find you handy.
(Red Green)
dtsman is offline   Reply With Quote
Old 02-10-2011, 07:27 PM   #5
Contractor - Renovations
fungku's Avatar
I would love to see that!
fungku is offline   Reply With Quote
Old 02-10-2011, 07:41 PM   #6
KemoSabe
loneframer's Avatar
Years ago, my boss bid a framing job that was to be built that way, due to the HOs daughter having acute allergies.
The building got framed to the beginning of the roof, all walls were 2x6s, standing vertical, side by side throughout the building.
The job ended up being shut down due to foundation failure and the walls were ordered taken down.
I wish I had pictures of that fiasco.
loneframer is offline   Reply With Quote
Old 02-10-2011, 08:30 PM   #7
fungku's Avatar
Old 02-14-2011, 04:27 PM   #8
Tell me where I'm going wrong. The 2 x 4's would be laid flat, 3 1/2" side down. It would take 64 2 x 4's (8',10',12' or however long you wanted your wall to be.) Would 3 1/2" of solid wood w/no gaps not be thick enough to provide enough insulation?
Old 02-14-2011, 04:39 PM   #9
Experienced
Jackofall1's Avatar
Check this out, one of many many many sites out there to get this information, and no, 3 1/2" of pine would not provide a very good R-value 4.38 to be exact.
http://www.coloradoenergy.org/procor...f/r-values.htm
Mark
Considerations when pouring concrete against a stucco wall? clint_nichols Building & Construction 9 09-24-2009 06:28 AM
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 04:43 PM
Temporary wall support question discojv Building & Construction 7 01-25-2009 08:23 PM
New wall construction, sheathing over openings Clutchcargo Building & Construction 7 11-29-2008 12:51 PM
Garage wall construction question Bjonas Building & Construction 4 01-01-2008 05:18 PM
