Walking In Attic - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-04-2010, 07:59 PM   #1
walking in attic
i own a 735 sqft home. the attic is approx 21 ft wide by 35 long. the trusses are made of 2x4's. The house was built in 2007.
I am 230 lbs. Will I crack the ceiling drywall joints if i walk in the attic? I know you are supposed to be able to walk on the rafters, but is there a weight limit? I don't want to find out the hard way....
big guy1 is offline   Reply With Quote
Old 03-04-2010, 08:41 PM   #2
Well, you can think of the drywall (not just the joints) as very weak concrete. We all know concrete has incredible compression strength, but it's tensile strength is horrendous.
I wouldn't risk it at all. I'm 180 and when I've been in attics and accidentally put one foot down on the ceiling, it flexes and I know right away that I've missed a joist.
Tonglebeak is offline   Reply With Quote
Old 03-04-2010, 08:49 PM   #3
thanks for that but what I meant was if i walk on the rafter itself, would the rafter bend and cause the drywall to crack? are the rafters designed to hold 230 lbs?
Old 03-04-2010, 08:53 PM   #4
Oh, that's how you're supposed to walk through attics without a subfloor. Of course, you're fine. The only load those 2x4s (on their side) will have to bear is you. Should be no issue, and what little deflection there may be won't hurt the drywall (normally).
The Following User Says Thank You to Tonglebeak For This Useful Post:
big guy1 (03-04-2010)
Old 03-04-2010, 09:01 PM   #5
I usually put planks down to walk on, helps spread the load out a bit
MIL's house the 2nd floor rafters are maybe true 2x4's
I use planks & walk around
Old 03-04-2010, 09:21 PM   #6
Registered User
Rewards Points: 526
If real trusses, made with #2 grade lumber, doug/fir, with a fink web design breaking the spans to 7', without real plaster ceilings or heavy cellulose insulation.......... They should support 227 total pounds. Subtract drywall ceiling (5/8"=2.75#)at 24" on center (5.5# x 7' = 39#), and fiberglass insulation (0.04# x 12" = 0.48#) plus 39# = 40# minus 227# = 187# for 7' between truss plate connectors.
What are the:
1.spans between connection plates at the webs,
2. insulation type, thickness,
3.ceiling material,
4.and on center spacing?
Be safe, Gary
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 19 08-23-2016 05:36 AM
Raccoons in the attic electricpete Pest Control 17 05-12-2011 04:02 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 12:42 PM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 05:06 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
