Walk Out Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-10-2013, 04:53 PM   #1
Rewards Points: 66
Walk out Basement
Walk out Basement
Hello, I have some questions. I am starting the plan to finish the basement but I am not sure if I should add extra frame, insulation and drywall or put directly the dry wall in the existing frame. This is the external wall, right now it's having some frame, insulation and vapor barrier, but the pipe for the AC are outside the wall so I am not sure if it's better to try to remove the existing insulation, put the pipe close to the wall (inside the frame) and put new insulation, or add and extra frame and more insulation to cover pipe. I am a newbie, please feel free for any suggestion. I am including a few pictures. Thanks
pavlito24 is offline   Reply With Quote
Recommended flooring for walk out basement Mark Harvey Flooring 2 08-08-2012 09:35 PM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 11:50 AM
Repairing Basement Walk Out Stairs (Cracks/Leaks) JakeFV Building & Construction 1 05-01-2011 04:57 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
