Vinyl Window Inserts - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-04-2011, 07:08 PM   #1
vinyl window inserts
my windows are 1/4 inch to big all around to fit in the R/O ; no return . what can I do to fix the problem?
Billf is offline   Reply With Quote
Old 01-04-2011, 07:17 PM   #2
Rewards Points: 6,652
Call up the person that measured the windows, and have them come back and remeasure and order the correct size. Really need pictures.
Old 01-04-2011, 07:54 PM   #3
Rewards Points: 162
New construction windows or replacements?
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 01-04-2011, 09:39 PM   #4
firehawkmph's Avatar
Rewards Points: 2,558
Bill,
Are your rough openings down to the studs, or do they have jambs and/or drywall from the old windows still in them? Pics would help like stated above.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
Tom Struble (01-04-2011)
Vinyl Window in Concrete Block Wrongwrench Carpentry 4 12-07-2010 10:21 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Vinyl window stuck in wood frame rlcarter Remodeling 7 09-26-2007 05:29 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 04:49 AM
