Vinyl Siding Help? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-12-2010, 07:48 PM   #1
Vinyl Siding Help?
Hi folks, I've just finished installing a new door that leads out to my deck via 3 stair treads. The door thatI replaced had some water damage under the threshold that let to it being replaced. I dont think the original installation addressed shedding the water properly. My question is what the heck to do with the area below the door.
Previously, there was a 5/4 x 6 peice of cedar under the sill of the door for support screwed directly to the sheathing (no vinyl siding under). Then below that was a 2 x 3 cca ledger board that the stairs were screwed to. This was lagged into the sill plate, this time through the siding.
I'd like it to be done properly this time. Any ideas would be greatly appreciated. I've attached photos that show the stairs sitting next to the area in question.
Vinyl Siding Help?-imported-photos-00000.jpg   Vinyl Siding Help?-imported-photos-00001.jpg   Vinyl Siding Help?-imported-photos-00002.jpg
Yellar is offline   Reply With Quote
Old 10-13-2010, 09:11 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
hhhmmm dosn't look like you installed a pan flashing under the door?
i never put siding under a door,i always install a kick plate
Tom Struble is offline   Reply With Quote
Old 10-14-2010, 06:34 PM   #3
Should I have installed a pan under the door? Would formed aluminum be acceptable?
A kick plate would be only about 5 1/2 " high. What to do with the area below that(behind stairs) which is another 5"?
Thanks for taking the time to respond.
Old 10-14-2010, 07:03 PM   #4
Rewards Points: 156
You could try something like this...
This is what I did for my new sliding patio door install. These steps were with the house when we bought it and I decided to keep them until I get time to put in a new deck. The kick board is PVC 1x4 under the door, then a piece of PT 2x6 under that, I think it was, and the steps were attached to this ledger board.
creamaster is offline   Reply With Quote
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 12:32 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
