Veranda Stair Removal - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-23-2011, 11:36 AM   #1
veranda stair removal
i want to remove the stairs and still leave the pad attached to the house. i want to put stairs on the front of the veranda instead. the area where the old stairs are is going to have a new pad to match the existing one with storage bellow for my green bin and garbage. will the existing pad remain intact or is it also held up by the stairs. the stairs are poured not preform.
brian a smart is offline   Reply With Quote
Old 03-23-2011, 12:15 PM   #2
Rewards Points: 558
Pictures would be nice. If your stairs are poured then you will probably have re-bar in bedded in them and will have to cut them as you use a demolition rotary hammer or back hoe to remove the steps from the veranda.
epson is offline   Reply With Quote
Stair Nose Attachment - HELP! BSponz1 Building & Construction 2 01-11-2011 08:51 AM
Stair Nose Attachment - HELP! BSponz1 Flooring 3 01-10-2011 02:31 PM
Lighting for stair risers jweiner Electrical 2 04-06-2009 06:18 AM
Stair framing question stubborn1 Carpentry 6 01-19-2009 12:12 AM
Lead paint removal Luken8r Painting 3 05-15-2008 08:05 PM
