Vent Hood Size/brick Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Bud9051
Old 11-04-2016, 09:56 PM   #1
Rewards Points: 153
vent hood size/brick wall
is there any code/requirement for the size of hole for exhaust fan on exterior brick wall? I need 8" for vend hood, not sure thats fine or i need reduce to 6/7"
s002wjh is offline   Reply With Quote
Old 11-04-2016, 11:13 PM   #2
Rewards Points: 70
Re: vent hood size/brick wall
The hood vent is 8"? Make the hole big enough for your weather cap insert. You can't reduce and get your air flow.
As for the structure, I can't comment to much on that. However, you likely only have a facade for brick, so not much structural weight at all.
Cheers!
supers05 is online now   Reply With Quote
Old 11-04-2016, 11:16 PM   #3
Rewards Points: 4,722
Can't answer your code question, but an issue often arises with large exhaust fans. What cfm is the fan and do you have any naturally drafted appliances like a gas water heater or furnace?
Sorry to drift a bit, but it's midnight and I have the time .
Bud
supers05 likes this.
Bud9051 is online now   Reply With Quote
Old 11-05-2016, 12:10 PM   #4
Rewards Points: 1,948
your manual should tell you but 6" is min. If you reduce it can increase noise and the venting cap of the hood. Everybody must have the core bit no greater than 6" because max I see everywhere is those 6" vents outside.
carpdad is offline   Reply With Quote
Old 11-05-2016, 12:14 PM   #5
Rewards Points: 153
thanks i mainly worry if there are any structural issue with 8" hole on brick wall. mine was build 2007 i think its brick veneers not positive. is most brick wall these day are veneer rather than load bearing?
Old 11-06-2016, 11:00 PM   #6
Rewards Points: 70
Yes, most are vaneer. From residential to commercial, it's all the same. (commercial will use concrete block behind though so at least they are closer, right?) Anyways, I've had to put 4, 6, 8, 10, 12" holes in brick walls before. Some round, some square. We've never had an issue with 8" causing cracks or anything like that.
Cheers!
How to vent toilet, sink and shower on vent located on different wall? luvdairish Plumbing 11 05-12-2013 02:31 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
Hood / Vent Requirements for Gas Stove WaldenL HVAC 1 09-09-2009 03:38 PM
can I 'patch in' a bathroom vent into my kitchen's stove hood vent? joeyboy HVAC 2 09-10-2007 12:36 PM
