Vapor Barrier For Bonus Room Over Garage? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-10-2018, 11:33 PM   #1
Rewards Points: 362
Vapor barrier for Bonus room over garage?
Hello All,
We just purchased a house and I'm having the carpet replaced in the bonus room which is over the garage. I've removed the original carpet and padding so there is only exposed 3/4 plywood at the moment.
Is there anything that you would recommend doing prior to having the new carpet installed? I'm in the process of screwing down the plywood, which was originally nailed, to eliminate some squeaks. However, should I also install any sort of vapor barrier or tar paper? I've used the later for hardwood flooring but not sure if anything is preferred under carpet?
Thanks,
Ralph
Ralph III is offline   Reply With Quote
Old 04-11-2018, 12:46 AM   #2
retired framer
Rewards Points: 6,056
Re: Vapor barrier for Bonus room over garage?
Originally Posted by Ralph III View Post
Hello All,
Thanks,
Ralph
The subfloor is considered the vapour barrier. The garage should be drywalled taped, filled and painted to keep auto off gasses out of the home.
Expanding laundry room into garage wilburn.johnm Flooring 2 06-22-2017 04:11 PM
Bonus Room over garage - question about span Fisherman67 Building & Construction 1 04-12-2017 02:22 PM
Remodel garage into a room. meaty Remodeling 5 02-12-2016 10:55 AM
insulation for bonus room over garage BrianinNC Insulation 33 06-25-2013 06:10 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-26-2011 12:58 AM
