Utlity Room In Garage Air Conditioning - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-11-2018, 03:56 PM   #1
Rewards Points: 60
Utlity room in garage air conditioning
My laundry, gas water heater, gas furnace are in a utlity room in my basement garage.
Water heater has metal gap exhaust vents outside through ceiling.
Furnace direct vent outside.
The room has big opening behind the furnace. Basically didnt put a last corner 2 feet on the room. This gives access to behind furnace and water heater. Im assuming if in need of servicing.
Can i finish this wall. Enclosed room so cool air does not cool the entire garage.
Door in utlity room has shutters to allow for air flow.
Im worried about the water heater exhaust getting in the hvac cool air.
Not sure if closing room off will change anything.
Or if there should not even be a vent in utlity room.
Dave
220 221 whatever it takes
Diy guy
brizzle is offline   Reply With Quote
Remodel garage into a room. meaty Remodeling 5 02-12-2016 09:55 AM
Building laundry room in garage Startingover Remodeling 18 09-05-2015 05:05 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-25-2011 11:58 PM
Cold Room mikelbeck HVAC 14 01-16-2009 08:21 PM
