Under Slab Vapor Barrier Building Procedure - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-08-2010, 06:15 PM   #1
Under slab vapor barrier building procedure
Do I have the pieces numbered in the correct order in which to lay them down ?
For example a roof with a pvc exiting a roof takes a seal on the top side so I was thinking to layer in the same manner to block the moisture from the under side. The #1 black 4 mil is sitting on top of #2 so you can see the size Im cutting the pieces but #1 would actually go on before/under #2. Or does the procedure really make a difference ?
Mudball is offline   Reply With Quote
Old 01-08-2010, 07:34 PM   #2
jlhaslip's Avatar
Rewards Points: 708
tape the edges and the order won't matter.
the poly under a slab is not to stop water from going down, it stops the ground water from coming up, so forget about the roof situation.
jlhaslip is offline   Reply With Quote
Old 01-08-2010, 07:49 PM   #3
Thanks jlhaslip I understand that the intrusion is from the underside. I guess I was too concerned about the steps of how they are installed.
Old 01-08-2010, 11:23 PM   #4
Registered User
Rewards Points: 526
http://www.100khouse.com/2009/06/24/...b-air-sealing/
http://www.stellarcontractors.com/as...loose_sand.pdf
Be safe, Gary
Old 01-09-2010, 01:48 AM   #5
jlhaslip's Avatar
Rewards Points: 708
Reading the loose sand article raises the question of 'how many basement slabs in houses have forklifts?'.
It appears the loose sand article deals with data from commercial projects. ie: warehouses with forklifts causing the cracks.
or did I miss something?
Old 01-09-2010, 07:28 AM   #6
Thanks for all the help. I had not planned on using sand in this application but can understand the controversy. As far as sealing the pipes go then it looks as though I might be on the right track.
Thanks again
Old 01-09-2010, 02:37 PM   #7
Registered User
Rewards Points: 526
Sorry, I clicked on the wrong one......... http://findarticles.com/p/articles/m.../ai_n25376326/
Thank you for catching that, jlhaslip.
Be safe, Gary
Building on existing concrete slab JimSpokane Building & Construction 2 07-22-2009 01:19 PM
building porch over concrete slab patio lachase Building & Construction 1 05-03-2009 01:43 PM
Building a shed, need help with pouring slab / fill ssybert Building & Construction 5 06-12-2008 06:19 AM
building a pole barn on a existing slab??? scott13676 Building & Construction 3 02-25-2008 06:29 PM
