Under Porch Cold Storage Metal Door Frame - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By 195795
  • 1 Post By Nealtw
Old 12-11-2018, 01:27 PM   #1
Rewards Points: 2
Under porch cold storage metal door frame
In my basement under the porch is a small concrete room with metal grate venting to make a cold storage area. When we finished the basement I walled off and insulated a larger shelf room for more storage but never bothered with putting a door on the concrete only section. Now I would like to put in a door to isolate the cold to just that concrete section.
The metal frame has me stumped though.
It looks like a door frame but with no provision or cutouts for hinges.
Has 3 machine screws on each side.
What is the best way to mount a door to this?
B52U is offline   Reply With Quote
Old 12-11-2018, 01:32 PM   #2
Rewards Points: 1,272
Re: Under porch cold storage metal door frame
You could mount the hinges using tapcon screws
Nealtw likes this.
195795 is offline   Reply With Quote
Old 12-11-2018, 01:37 PM   #3
Rewards Points: 7,056
Is there room to add a wood frame inside the metal frame?
Pictures might help.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now   Reply With Quote
Old 12-11-2018, 01:40 PM   #4
retired framer
Rewards Points: 1,512
The part with the screws are the door stop and the door would go on the basement side
How wide and high is the opening there?
Old 12-11-2018, 01:43 PM   #5
retired framer
Bud
I have the picture, it is like this with out hinge cut outs.
http://www.proindustries.com.au/arch...frames-masonry
Old 12-11-2018, 01:46 PM   #6
Rewards Points: 2
The inner dimensions of the stop are 81" high by 34" wide.
The larger opening is 82.5" high, 36" wide.
Old 12-11-2018, 01:58 PM   #7
retired framer
That should take an exterior metal door, measure before you buy.
The hinges will want to be set double deep to allow for the surface mount on the frame. You will have room at the bottom to install some sort of threshold. The door should come at 35 3/4 wide.
Bud9051 likes this.
The Following User Says Thank You to Nealtw For This Useful Post:
B52U (12-11-2018)
Asphalt roofing Transition to Metal Roof BigJim Roofing/Siding 7 04-13-2018 09:10 AM
Cold Room insulation / finishing options kal72 HVAC 11 10-16-2017 09:59 PM
Rear porch metal roof LeeN Roofing/Siding 0 08-20-2011 10:06 AM
1927 Metal porch roof/Deck 4'x6' (EDPM or Rolled roofing). greenhornet Roofing/Siding 2 09-22-2009 10:49 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
