Tying Addition To Existing Roof Line - Building & Construction - Page 4 - DIY Chatroom Home Improvement Forum
Like Tree4Likes
Old 07-01-2019, 04:22 PM   #46
retired framer
Rewards Points: 6,062
Re: Tying addition to existing roof line
Originally Posted by URY914 View Post
Here another question,
My current roof uses 1 x 6's not plywood. Therefore when I tie the new addition's roof into the existing roof there will be a visible line which will telegraph through the roof surface. To avoid this I need smooth out the transition. I'm thinking I need to lay my first piece of 7/16" plywood against the 3/4" and then over lay a single sheet of 1/8" underlayment boards and an extra layer of felt paper to ease the transition. Then at 4' out I'll delete the underlayment and use just a extra layer of felt. At the 8' mark I'll just be using the 7/16" with a single layer of felt and continue out for the rest of the new roof.
Thoughts?
Put 1/8 shims on the rafter or cut tapers so it is more gentle. With 3 ply shingles it will not be bad.
Do not use flat bottom gables with scissor trusses.
2nd Floor Addition on existing Flat Roof of Workshop shoptalk Building & Construction 0 03-06-2013 01:10 PM
connect one existing gable roof to an addition im building onto house at end in an l shaped design srdavis Building & Construction 4 01-28-2013 09:58 PM
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 06:12 PM
Hip Roof issue with addition woody9911 Roofing/Siding 6 01-16-2011 05:43 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
