Tying Addition To Existing Roof Line - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Like Tree4Likes
Old 04-24-2019, 08:03 PM   #31
Rewards Points: 76
Re: Tying addition to existing roof line
Originally Posted by Nealtw View Post
You said it was 2/12 pitch, on that 2x8 measure back from the point 12" and measure square down for the height, it looks like 3 or 4/12 to me.
I measured it this evening. 12" over and 2 1/2" down. 2.5/12.
Nealtw likes this.
URY914 is offline   Reply With Quote
Old 04-24-2019, 08:14 PM   #32
retired framer
Rewards Points: 5,948
I have never stick framed one like that, it would one day to build it with trusses. Even that takes some head scratching.
Do not use flat bottom gables with scissor trusses.
Old 06-12-2019, 06:53 PM   #33
Rewards Points: 76
Here's an update. This one was taken yesterday...
Old 06-12-2019, 06:55 PM   #34
Rewards Points: 76
This one was a week or so ago...........
Mystriss likes this.
Old 06-12-2019, 06:57 PM   #35
retired framer
Your walls should be sheeted or you should have angle braces on the walls.
But it is looking good.
Old 06-13-2019, 10:25 AM   #36
Rewards Points: 76
If you look close you'll see 1/2" rods from the top plate down to the curb. The walls are very secure.
Old 06-13-2019, 02:44 PM   #37
retired framer
I wouldn't trust it, but if you think they can't move.
Old 06-13-2019, 08:02 PM   #38
Rewards Points: 76
The rods thread into these embeds in the curb 48" o.c. and at each side of doors, window and corners. The walls aren't going anywhere.
Nealtw likes this.
Old 06-13-2019, 08:57 PM   #39
retired framer
You do have lot's of bolts.
Have you checked about ho much you will have to cut off the engineered beam
i have seen that discussed on line but I can't find it.
Old 06-13-2019, 09:55 PM   #40
retired framer
Old 06-25-2019, 02:07 PM   #41
Rewards Points: 76
Neal,
Haven't checked with the engineer on cutting the beam yet.
But I have another question: Should I use Zip System sheathing or good old fashion 7/16' plywood and tyvak wrap. I'm thinking this is a plywood and wrap job. No need to spend extra $$ on a garage/workshop addition. Agree?
Old 06-25-2019, 02:16 PM   #42
retired framer
Neal,
Haven't checked with the engineer yet on cutting the beam yet.
I have no experience with Zip but either system, it is all about proper installation and flashing. I don't see an advantage to adding expense if you do the other properly.
Old 06-25-2019, 02:22 PM   #43
Rewards Points: 76
I've done my YouTube research on Zip System and it does have some advantages but plywood/wrap is pretty foolproof and cheaper.
Old 06-25-2019, 02:34 PM   #44
retired framer
Nothing is fool proof but any problems we see are are about poor installation and if you use zip you still have to join and water proof to the house so you would be doing both.
Old 07-01-2019, 03:41 PM   #45
Rewards Points: 76
Here another question,
My current roof uses 1 x 6's not plywood. Therefore when I tie the new addition's roof into the existing roof there will be a visible line which will telegraph through the roof surface. To avoid this I need smooth out the transition. I'm thinking I need to lay my first piece of 7/16" plywood against the 3/4" and then over lay a single sheet of 1/8" underlayment boards and an extra layer of felt paper to ease the transition. Then at 4' out I'll delete the underlayment and use just a extra layer of felt. At the 8' mark I'll just be using the 7/16" with a single layer of felt and continue out for the rest of the new roof.
Thoughts?
2nd Floor Addition on existing Flat Roof of Workshop shoptalk Building & Construction 0 03-06-2013 01:10 PM
connect one existing gable roof to an addition im building onto house at end in an l shaped design srdavis Building & Construction 4 01-28-2013 09:58 PM
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 06:12 PM
Hip Roof issue with addition woody9911 Roofing/Siding 6 01-16-2011 05:43 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
