Trusses For Addition - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-31-2009, 09:30 PM   #1
trusses For Addition
I'm adding on to my house. I have a 24' x 30' slab poured. I want to span 24' with trusses. What should I use to build the trusses? 2x4 or 2x6 or something bigger? Also, the bottom of the trusses (the joists), should I spilt the 24' into 3rds using 8' lumber or do it in 2 pieces using a 16 footer with a 8 footer?
1967jsr is offline   Reply With Quote
Old 08-31-2009, 10:01 PM   #2
Rewards Points: 1,016
I would suggest to use a qualified truss manufacturing company - who will do the proper engineering and construction and deliver them onsite ready for you to install. You will then have a properly built roof structure plus pass building inspection without issue.
Old 08-31-2009, 11:04 PM   #3
Rewards Points: 150
Ditto sheetz, When I did my addition it only cost me about $120.00 a truss 6/12 pitch 28' long with overhang, raised heel. Delivered to the house. It's not worth the hassel of building them, plus you have to make some kind of jig to make sure they are all perfectly the same. And also you might want to look at some of the designs they have available as far as bonus rooms built into the truss for attic storage or a scissor truss to give a cathedral look inside.
James Con is offline   Reply With Quote
Old 08-31-2009, 11:18 PM   #4
Registered User
Termite's Avatar
The engineering on the home-made trusses that will inevitably be required by any heads-up building inspector will cost a lot. Enough to offset the cost of having a truss company fabricate (and engineer) them for you. It really is very inexpensive, and is a much much much better idea than trying to do it yourself without an understanding of the ways trusses manage the imposed loads.
Old 09-01-2009, 06:40 AM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
It was touched on above, but to make it a little more clear, a truss manufacturer will provide you with all the documentation you need about wind/snow loading, bracing and fastening requirements to satisfy your building inspector.
Building Garage with Engineered Trusses twiles Carpentry 30 03-12-2016 08:17 PM
Pre-Manufactured Trusses or not? my5sons Building & Construction 7 04-13-2012 12:44 PM
Mounting something to trusses bluefitness Building & Construction 1 07-19-2009 06:11 PM
Setting trusses for a Hip roof? TonyGG Building & Construction 13 09-13-2008 08:47 AM
How to line up trusses with studs aero_ub Carpentry 5 04-24-2006 03:48 PM
