Truss Connector Plates Seperating - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 2 Post By woodsmith.ryan
  • 1 Post By Bud9051
  • 1 Post By Nealtw
Old 03-05-2018, 04:36 AM   #1
Rewards Points: 26
Truss connector plates seperating
I am building a garage and I was very upset to see that several of the truss connector plates in the middle of the bottom chord are separating. This seems like a serious problem to me.
What do you all say about this? Is this common? Is it a manufacturer defect?
Should I pound them back together? Use clamps?
https://ibb.co/kvtFCn
https://ibb.co/n5HLdS
https://ibb.co/jDcgk7
woodsmith.ryan is offline   Reply With Quote
Old 03-05-2018, 06:00 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 960
Re: Truss connector plates seperating
It appears there is a floor installed with tube heating. Was the truss approved for such an overhead load? Most trusses aren't able to handle such loads without central support.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 03-05-2018, 07:48 AM   #3
Rewards Points: 7,042
I agree with Larry looks like a loading issue. But the people to ask are those who built the trusses. I'm not a truss expert but my opinion is, remove all load from above asap. If not designed for that loading, have the truss company design any possible improvements.
Repairing those plates involves more than just pushing them back into place and that is where the truss mfg needs to be contacted.
Bud
Bud9051 is online now   Reply With Quote
Old 03-05-2018, 10:29 PM   #4
Rewards Points: 26
They are attic trusses, so they are approved for having a floor on top. The building is still in construction and as of now, the only load is the empty pex tubing and the subfloor resting on the trusses. Thanks guys, Ill contact teh manufacturer.
Bud9051 and chandler48 like this.
Old 03-06-2018, 08:20 AM   #5
One point you might want to determine if possible is, were those trusses delivered in that condition or damages during the installation. Trusses are very strong in their vertical orientation, but laying flat they bend like a wet noodle. If these were handed up over the walls a careless worker/s could have bent them more than they should. The truss mfg will know. My guess is they did not leave the factory like that and even if they did the framers should have noted and started the repair or replacement process. Weight seems to be on their shoulders.
As for repair some manufacturers have portable equipment but you should maybe run some strings to be sure they are still straight from wall to wall.
Bud
MTN REMODEL LLC likes this.
The Following User Says Thank You to Bud9051 For This Useful Post:
firehawkmph (03-07-2018)
Old 03-06-2018, 08:26 AM   #6
retired framer
Rewards Points: 1,370
The instruction show clearly that you are not to pull them up using leverage to get them on the building. Talk to the truss company and then do as you are told.
You will likely need a hanger nail gun. Then send hem pictures of the repairs. It's about making the warrantee good.
Old 03-06-2018, 08:32 AM   #7
LOL,Neal, I had to chuckle, when was the last time you saw a framing crew reading truss instructions. Building layout yes, but any "how to" instructions, not.
Bud
Old 03-06-2018, 08:38 AM   #8
retired framer
Bud
We always had a crane drop them on the building so those pages were always first to hit the floor. But the instructions take the truss company off the hook.
https://www.cecobois.com/publication...usses-tpic.pdf
truss uplift jklingel Drywall & Plaster 2 04-24-2013 12:18 AM
Sheet rock and truss uplift jklingel Building & Construction 13 01-04-2013 10:46 PM
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 09:45 PM
2nd story ledger to floor truss fisherk Carpentry 1 10-18-2008 01:08 PM
Gambrel Truss Dormer and Ladder Framing? fauer Carpentry 3 09-30-2007 08:36 PM
