Trimming End Of Glulam Beam? - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By 123pugsy
Old 06-25-2017, 01:18 PM   #1
Rewards Points: 207
Trimming end of glulam beam?
So I have a beam that spans an opening on an addition. I'd like to trim the top corner of one side, at an angle, to accommodate the roof line that will come down to the wall. Not sure if there are specs for trimming beams, like there are for notching joists.
I've attached a drawing of the situation.
wease is offline   Reply With Quote
Old 06-25-2017, 06:06 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Trimming end of glulam beam?
Around here, the use of a Glulam is according to Engineered drawings, so the Engineer of Record would be the best guy/gal to answer your question.
Approximately how deep of a triangle would you be removing?
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 06-25-2017, 06:22 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 30,548
Doesn't look like much of a bearing point on the wall. Has that been approved?
Old 06-26-2017, 04:00 AM   #4
retired framer
Rewards Points: 6,172
There are rules to how much you can cut but most engineers look pissed when you ask them because they didn't think about it when the designed the project. Take off as little as possible to allow for sheeting is the usual answer.
If you have to come down a third the height you may want to think about lowering the beam.
Old 06-26-2017, 07:27 AM   #5
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,530
Found this.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Old 06-26-2017, 06:08 PM   #6
retired framer
Originally Posted by 123pugsy View Post
Found this.
The effective size of the beam has changed, for that much I would consult an engineer.
Old 06-26-2017, 06:55 PM   #7
123pugsy's Avatar
Thanks.
Yes, any post here is just a guideline. OP should consult an engineer or the glue lam supplier.
Nealtw likes this.
Old 06-26-2017, 08:17 PM   #8
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,578
thats just a quick hand sketch,,, no dimensions are shown. .they may have more bearing than shown
woodworkbykirk is offline   Reply With Quote
Vaulted Ceiling Glulam Beam Connections goldenfab Building & Construction 7 05-17-2017 01:08 PM
Flush Beam Install jeffa123 Building & Construction 4 07-20-2015 11:27 AM
L shaped porch framing onjtrainee Building & Construction 34 02-07-2015 08:10 PM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Hanging loft from glulam beam, pics inside. wackerjr Building & Construction 20 01-05-2011 09:55 PM
