Trim Joins At Base Of Sloping Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-04-2013, 09:49 AM   #1
R0X
Trim joins at base of sloping wall
Hi - I'm finishing my basement and have a question about trim; I need to ask it with reference to the attached diagram.
I've added a piece of 1 x 8 with routed edges to surface "A", and want to attach either quarter round or the other trim in the diagram (both profiles inset) under the 1 x 8 piece. The partial wall rises at about a 36 degree angle.
My question is: How would you join the trim ends at corners "B" and "C"? Thanks in advance for any suggestions.
R0X is offline   Reply With Quote
Old 04-04-2013, 09:56 AM   #2
AHH, SPANS!!!
Rewards Points: 1,166
base cap is a much better look turned upside down butted up underneath the top 1x8. you can either wrap the outside corner with the base or make a return that stops the base at the outside corners. the wrapped around base would be a 36 degree cut on the vertical and 45 degree to make the outside corner...
hand drive is offline   Reply With Quote
Old 04-05-2013, 07:23 AM   #3
R0X
Thanks, I'll try that this weekend.
Old 04-05-2013, 09:34 AM   #4
Roofmaster
Rewards Points: 2,220
You split the angle at the miter. 63 degrees.
Old 04-05-2013, 09:49 AM   #5
Rewards Points: 18,118
Angles like that is one reason I like using one of these.
http://www.rockler.com/product.cfm?p...9&site=ROCKLER
Instanly gives me the angle to cut for a single or double cut.
Old 04-05-2013, 10:09 AM   #6
Roofmaster
Joe, just how many toys do you have????
Use one of the gizmos Joe shows, or use a piece of paper. Transfer to paper and fold in half.
You rounded the corners of the 1 x 8 and ran it past (Cantilevered) about 2.5 inches right?
By the way, OP great illustration, very clear.
Old 04-05-2013, 10:18 AM   #7
Let's put it this way, I can get a tool catalog and not seeing anything I need.
I can cut though the tool isle at Lowes or HD and not touch anything.
I had so many hand tools I started giving my extras to the high school shop class.
All I buy now is sand paper, and saw blades.
Old 04-05-2013, 10:27 AM   #8
Roofmaster
Yeah, Im just as bad. I even have two of most things. It's a sickness.
Old 04-05-2013, 10:57 AM   #9
I had way more then that at one time, I was trying to run three crews on 3, differant jobs so I had to have three trailers full of tools, a 30 ft. constrution trailer plus a garage full.
I dumped all my sockets out and sorted them and found I had at least 8 of every size, why I have no idea.
3, table saws, two jointers, two planers.
I was spending more in tools a week then my exwife was making in a week.
Old 04-05-2013, 11:52 AM   #10
Roofmaster
Maybe that's why she is your X-wife, you did not buy, or use the right tool enough.
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 01:26 PM
Retaining wall concrete base -- how thick? RDS Landscaping & Lawn Care 1 04-23-2010 02:10 PM
trim for doors that are flush with the wall aldous314 Carpentry 2 04-07-2010 11:44 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
crown molding sloping wall and standard wall Alex007 Carpentry 12 03-13-2010 09:56 AM
