Top Top Plate - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By jlhaslip
Old 06-19-2016, 09:42 PM   #1
Rewards Points: 996
top top plate
stud wall is built. how many and how should i nail on the top top plate ?
thanx
Fix'n it is offline   Reply With Quote
Old 06-19-2016, 10:30 PM   #2
JUSTA MEMBER
Rewards Points: 392
Re: top top plate
To prevent the shed from twisting, at least one across the joints between the sides and front/back.
You need to cover the seam between them at least once with an upper plate, and then depending on what you plan for a roof, maybe another with the pitch built in to allow rain runoff.
These are integrated with the sheathing and siding as a unit to strengthen the walls.
ED
Editing: I personally screw everything together, nails tend to pull out over time.
de-nagorg is offline   Reply With Quote
Old 06-19-2016, 10:35 PM   #3
jlhaslip's Avatar
Rewards Points: 708
Re: top top plate
Overlap the corners as pointed out above.
I set two nails at each stud and try not to nail between studs in case the Electrician and /or the Plumbers need to drill holes between studs.
For a shed, this is not as large of a concern.
de-nagorg likes this.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 06-19-2016, 10:52 PM   #4
Rewards Points: 996
Re: top top plate
the corners are overlaped ( i have built only the back and 1 side wall yet)
like this pic.
https://jamesawatt.files.wordpress.c...-016.jpg?w=529
Old 06-19-2016, 10:56 PM   #5
JUSTA MEMBER
Rewards Points: 392
Re: top top plate
Build all 4 corners like that and you have plenty to start adding a rafter set.
That will be great.
ED
The Following User Says Thank You to de-nagorg For This Useful Post:
Fix'n it (06-19-2016)
Building a 2nd shed adjacent to existing... iThinman Building & Construction 60 12-10-2015 10:52 AM
Should I insulate my sill plate? LVDIY Insulation 5 11-14-2015 06:44 PM
Sill plate attachment to foundation WillK Building & Construction 3 10-12-2015 02:28 PM
Riello 40 Series, Air Adjustment Plate RCrosby257 HVAC 1 06-22-2015 05:31 AM
JAcking up floor to replace bottom wall plate. tpicklesimer Flooring 0 05-24-2011 08:08 AM
