Thread Tools | Display Modes |
#1 |
I have gas!
Rewards Points: 1,902
![]() Tongue and Groove Deck Ceiling finishing.
I have a roof over my deck and it is just exposed dimensional lumber right now. I want to add 1x4 tongue and groove pine ceiling to give it a finished look.
I'm going to finish the boards before I install. Should I coat both sides or is one side enough? My thought is that with one side left exposed it would cause cupping... not sure. As usual, any insight/tips/tricks is appreciated. Thanks
I tear things down and build them up. |
Sponsored Links | |||
Advertisement |
#2 |
JUSTA MEMBER
Rewards Points: 372
![]() Re: Tongue and Groove Deck Ceiling finishing.
That is a definite possibility.
A thought that I had was that any moisture that might get in there from atmospheric condensation (dew) would cause the unfinished side to grow fungi and possibly rot faster. ED |
Advertisement |
#3 |
I have gas!
It's vented so I'm not too worried about rot in the roof structure and besides the other components (rafters and roof sheathing) won't be painted. I would rather put an ounce of prevention instead of a pound of redoing the roof because it cupped and looks like crap.
What is standard practice when it comes to stuff like this? de-nagorg likes this.
I tear things down and build them up. Last edited by Clutchcargo; 09-12-2016 at 11:37 AM. |
Advertisement |
#4 |
Remodel and New Build GC
Rewards Points: 298
I sure would coat both sides.... easy inexpensive insurance protecting a appearance important ceiling.
(I even often paint both sides of a ship lap pine siding repairs when the siding is especially exposed/prone to moisture) de-nagorg likes this.
Never stop learning (xcep fer speling en typeing) ![]() Last edited by MTN REMODEL LLC; 09-12-2016 at 12:03 PM. |
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post: |
oh'mike (09-12-2016)
#5 |
Rewards Points: 1,466
Depends on the wood. I have tongue and grove redwood on the ceilings of three bathrooms in my house, zero finish anywhere, looking just fine thirty years later. I also I have shiplap pine in a two story forty foot long atrium that has been given a minwax stain both sides, same thing thirty years later, that is to say no worries. Ron
#6 |
Rewards Points: 128
If the ceiling is exposed to outdoor conditions -- not necessarily rain but just to the normal, seasonal variations of temp and humidity you have a good chance of cupping if you don't paint both sides. Can't guarantee it will cup if not coated on all sides but if it does you will never be able to correct it.
#7 |
Rewards Points: 2,902
Paint or otherwise seal the edges, too.
Just my 7 cents (2 cents after taxes and inflation). |
#8 |
Rewards Points: 262
Cupping is result of wet/dry cycle, esp by sun's heat. Your 1x ceiling probably is already dried lumber and your nailing for t&g should also keep from cupping. That said, it is still outdoor condition and as stated, it is cheap insurance. Won't keep it from molding if constant moisture is allowed. You probably already know but make sure the roofing nail won't come through.
#9 |
I have gas!
Thanks all, I'll coat both sides.
jlhaslip likes this.
The Following User Says Thank You to Clutchcargo For This Useful Post: |
de-nagorg (09-13-2016)
Advertisement |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Is drywall required under tongue & groove ceiling? | ZZZZZ | Building & Construction | 9 | 12-25-2015 12:05 PM |
Staining to match discolored wood tongue and groove ceiling | DIY808 | Painting | 7 | 03-10-2015 10:48 PM |
Insulating a Tongue and Groove Cathedral Ceiling | tikitacky | Insulation | 9 | 02-05-2013 12:17 AM |
Tongue and Groove Ceiling install....questions... | Dr. Jim | Remodeling | 9 | 04-08-2012 01:14 PM |
Tongue and groove patio ceiling nailers | Dave DB | Carpentry | 7 | 08-05-2009 01:46 AM |
