Tiny Gap In My Front Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-27-2014, 10:25 AM   #1
Tiny gap in my front door
I have a tiny gap at the bottom of my front door through which I can see daylight. I'm worried about bugs getting in, as well as heat from outside getting in.
Here's the worst picture ever of it, but you can see the daylight coming in - http://i.imgur.com/ifIoNZ4.jpg
This foam thingy was previously wedged in there, but the adhesive has come off and I can't get it back in there properly - http://i.imgur.com/vfFLm7G.jpg
So two questions -
1) I suck at this sort of thing, and I cannot remember which "direction" the foam thingy was wedged in the door to make a proper seal. I've tried various ways, but the door opening/closing always rubs against it and eventually dislodges it. Any advice on sticking it back in there?
2) Is there a better way to close this gap?
Thanks in advance!
larry613 is offline   Reply With Quote
Old 05-27-2014, 11:31 AM   #2
Rewards Points: 18,384
First pictures not coming up for me.
The second one is just to keep water away from the seam where the threshold meets the jamb.
Most common causes of air leaks is the thresholds not level, loose or stripped hinge screws, no support on the outside under the sill, or the doors not hung square and plumb.
Old 05-27-2014, 11:39 AM   #3
Rob
Robpo's Avatar
Rewards Points: 826
It is there it is the inverse of an ant in a snow storm.
Robpo is offline   Reply With Quote
Old 05-27-2014, 11:52 AM   #4
Sorry - I know that first picture is crap.
I've run it through photoshop and lightened it up a bit. The gap is in the bottom right of the door.
http://i.imgur.com/PBaDPI0.jpg
Old 05-27-2014, 01:22 PM   #5
Rewards Points: 398
The rubber door seal looks too short - buy a new section from your hardware store, cut it to size and place back in.
The old one should pull right out.
Tiny gap in my front door-image-2108020841.jpg   Tiny gap in my front door-image-3673247654.jpg
Central New Jersey Area
adgjqetuo is offline   Reply With Quote
The Following User Says Thank You to adgjqetuo For This Useful Post:
hand drive (05-27-2014)
Sidelight replacement on front door. jeffdoesrepairs Windows and Doors 8 06-29-2013 10:01 AM
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 08:08 PM
Front load Amana washer leaking from inside of door! Stephenby Appliances 4 06-10-2012 07:38 PM
Installing new front door...... Any tips ????? ogoz23 Remodeling 32 05-13-2012 11:10 PM
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 08:22 AM
