Tile Edging/Rounding - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-16-2011, 07:46 AM   #16
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Soldiers.
XXX
Old 02-16-2011, 08:07 AM   #17
Steeler99's Avatar
Can you elaborate on soldiers?
Steeler99 is offline   Reply With Quote
Old 02-16-2011, 10:11 AM   #18
Steeler99's Avatar
can someone please explain to me what soldiers means? I haven't got a clue what Bud's referring to
Old 02-16-2011, 11:45 AM   #19
Contractor - Renovations
fungku's Avatar
Originally Posted by Bud Cline View Post
All the sinks were curved. Where would you find a square sink?
that's kind of what I was implying.
Soldiers.
ahhh...
masonry/brickwork reference.
fungku is offline   Reply With Quote
Old 02-16-2011, 11:53 AM   #20
Steeler99's Avatar
I know what a soldier course is in masonry/brickwork....I don't see how that applies here. Soldiers is placing brick or masonry units vertically, and I'm failing to make the connection to how that relates here.
Hypothetically speaking, if you were using 4x4 tiles on the countertop...what would you do to tile the vertical edges of the sink in the curved corners? Cut a bunch of half inch strips to piece the radius together?
Old 02-16-2011, 12:09 PM   #21
fungku's Avatar
Like a brick arch
Old 02-16-2011, 12:17 PM   #22
Steeler99's Avatar
yeah, I believe I get that part...that's for the horizontal flat part of the countertop, or the surface shall we say.
But what about the sink cutout part....there'll be a vertical edge there all around the sink. That edge I'm referring to is the thickness of the countertop. What do you put in those corners is what mean. Those radii are very small, usually less then three inches
Old 02-16-2011, 01:14 PM   #23
fungku's Avatar
Lay the brick arch down and those bricks are soldiers and can make a pretty tight radius. That is what I was assuming bud was talking about.
(that image is actually of a wood kiln under construction... pretty cool-looking)
Old 02-16-2011, 02:47 PM   #24
Steeler99's Avatar
well, honestly I'd love to see a photo of a tile countertop with an undermount sink showing as bud mentioned, I can't see that working in such a tight radius without having it look choppy.
I've been searching for photos of an undermount sink with tile counterop, and I can't seem to find anything.
Old 02-16-2011, 03:09 PM   #25
fungku's Avatar
i wouldn't want it, but some people will do a lot of work and put up with a lot to save a buck.
Old 02-16-2011, 03:25 PM   #26
Steeler99's Avatar
Well, I understand that logic too
Old 02-16-2011, 04:50 PM   #27
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Calm down, calm down...some of us have to work you know?
There ya go!
You are making this way too difficult. I looked but don't have any pictures of the sinks with the radius pieces showing. Not much into pictures these days. Work out what size will fit the small radii, cut the little beggars and place them on the vertical. cover the top edge with arch-cut bull nose pieces. The soldiers should be cut on all four sides for them to look right in my thinking and they should be rectangular in my opinion for the best look. Once they are in place and grouted they will enhance the decorative aspects of the sinks.
XXX
Old 02-16-2011, 05:57 PM   #28
fungku's Avatar
Haha... sitting here waiting for my next job to start
At least I have night classes and forums to keep me sane
Old 02-16-2011, 06:51 PM   #29
Steeler99's Avatar
Hey bud, if you wouldn't mind, I'd very much appreciate you posting photos of jobs you've done with the situation we're discussing. I would like to see how it looks when completed. I have this image in my mind of 5 or 6 tiny little tiles (1/2" x 1 1/2") piecing this corner together. For some reason, I'm almost seeing more grout than tile in the corner.
I certainly don't mean to question you authority on the matter, its just that I've never seen an undermount sink with a tile countertop..well, I have, but not in the situation we've been discussing. Nor have I ever met a contractor willing to do as you mentioned.
Then again, I'm not an expert or anything, so my knowledge on this matter is very limited with this.
Old 02-16-2011, 10:30 PM   #30
Tileguy
Bud Cline's Avatar
Rewards Points: 558
As stated in my earlier post: "I looked but don't have any pictures of the sinks with the radius pieces showing. Not much into pictures these days."
...and the problem with that is...?
XXX
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 09:07 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
