Are These Windows Installed Correct? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-19-2010, 05:16 PM   #1
are these windows installed correct?
W e had 9 windows and 3 doors replaced with new construction windows /doors Milgard (paid $ 7400). The job was done by a big company specialized in windows. We wanted to remodel our house and put stucco on it, so we had the windows replaced first. Now, all the stucco contractors that are coming over are telling us that the windows are not properly installed (are inside not at the wall level), and for sure will leak. Also, the windows doesnít have the proper insulation, flashing paper is only at the bottom and also have the paper cut it at corners. In order to fix this they recommend to take them all off and reinstall it properly and it will cost us aprox $ 3,000. After talking to more than 20 contractors they said that they never saw such a sloppy job. Photos are attached. Please help me with advice.
are these windows installed correct?-window-problem.jpg   are these windows installed correct?-window-problem2.jpg   are these windows installed correct?-window-problem4.jpg   are these windows installed correct?-window-problem-3.jpg
michelleb is offline   Reply With Quote
Old 08-19-2010, 05:38 PM   #2
Rewards Points: 5,348
This company should have these installers thrown into a wood chpper. I count 7 screws holding the windows in.
This is an incompetant window installation.
Ron
Old 08-19-2010, 06:07 PM   #3
kwikfishron's Avatar
Rewards Points: 846
Definitely not installed to Milgard specifications.
At this point this may be a good thing for you. I’m going to assume you pulled the trim off for the picture.
In Oregon you could file a complaint with the Contractors Board and the window company would have to fix this or pay and maybe fined.
What State are you in?
kwikfishron is offline   Reply With Quote
Old 08-20-2010, 12:35 PM   #4
At this point this may be a good thing for you. Iím going to assume you pulled the trim off for the picture.
they took the trim off before installed the windows and left it this way in order for us to put stucco . But no stucco company want it to garantee the job with this windows... We live in California.
Old 08-20-2010, 01:09 PM   #5
This is an installation you would see done by a homeowner who listened to advice from a big box store.
Contact Milgard and send them pictures. I'm sure they would be interested in how their products are being handled.
Ron
Old 08-20-2010, 01:18 PM   #6
fabrk8r
fabrk8r's Avatar
Wow! That's a terrible installation job. They didn't even follow instructions to allow for stucco.
I think that as a homeowner you could have done a better job even if you had no experience installing windows before.
I hope you can at least get some money back. Don't let those hacks back on your property.
I like how they wiped the excess caulk that they got on their finger right onto the window casing.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-20-2010, 04:14 PM   #7
Registered User
Rewards Points: 526
I'm impressed they installed them with the weep holes on the bottom--- correctly. The sheet metal ?? screws are not even in the pre-punched holes on the fin.... and a 3/4" air space gap at the head? 3 minute install. Correction, 2 minute.
Be safe, Gary
Old 08-20-2010, 04:36 PM   #8
Rewards Points: 846
Look at this Michell.
http://www.cslb.ca.gov/Consumers/FilingAComplaint/
And this.
http://pro.milgard.com/_doc/products...ma-2400-02.pdf
Need correct steps for install OSB, Tyvek, Windows tljbcrew Building & Construction 0 08-09-2010 10:35 AM
Basement Vinyl Windows - replace or not, thats the question! chadurban Carpentry 0 10-01-2009 10:37 AM
Badly Installed aluminum double hung windows in a rental Mrnagrom Remodeling 3 01-07-2009 01:31 AM
Thermal Barrier Windows vs Vinal Windows MeraleeCrowl Remodeling 6 11-05-2008 04:46 PM
MW Vinyl windows w/ JChannel + Hardi Board Siding - Proper Flashing? jboeckler Building & Construction 1 09-20-2008 02:55 PM
