Are These Post Cracks To Be Concerned About? - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree7Likes
  • 4 Post By chandler48
  • 1 Post By Hossenfeffer
  • 1 Post By CodeMatters
  • 1 Post By jlhaslip
Old 04-08-2018, 01:01 PM   #1
Rewards Points: 133
Are these post cracks to be concerned about?
Large posts in central post and beam of my sister's townhouse have these cracks. I assume all the units in the complex are the same...built in 2006. Any reason for remedy or is this ok?
Thanks for any info.
Are these post cracks to be concerned about?-1.jpg   Are these post cracks to be concerned about?-2.jpg   Are these post cracks to be concerned about?-3.jpg   Are these post cracks to be concerned about?-4.jpg   Are these post cracks to be concerned about?-5.jpg
Hossenfeffer is offline   Reply With Quote
Old 04-08-2018, 01:22 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 1,334
Re: Are these post cracks to be concerned about?
They are called "checks" and are completely normal, although not eye appealing. It is possible to fill the checks with something like an epoxy filler, but you may not get a stain match, and nothing is to say the checks won't enlarge. I would leave them alone, since they are structurally sound for their purpose.
Bondo, mark sr, CrazyGuy and 1 others like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 04-08-2018, 02:09 PM   #3
Rewards Points: 133
Thanks. As I thought. No there will be not need to fill them.
Nealtw likes this.
Old 04-12-2018, 08:13 AM   #4
Rewards Points: 1,602
Are those solid wood or is there a veneer wrapped around metal or less slightly wood?
mikegp is offline   Reply With Quote
Old 04-12-2018, 08:33 AM   #5
CodeMatters's Avatar
Rewards Points: 7,478
Fill jobs I've seen looked ok initially but terrible a few years later. Natural
checked look has character.
mark sr likes this.
CodeMatters is offline   Reply With Quote
Old 04-12-2018, 04:19 PM   #6
Rewards Points: 14
General rule of thumb I was given: checks that follow the grain of the wood are likely normal shrinkage and usually not a problem. Checks against the grain or involving a large part of the beam’s radius may need to be looked at.
EdBoston is offline   Reply With Quote
Old 04-12-2018, 06:58 PM   #7
retired framer
Rewards Points: 6,172
Look for stain and finish in the cracks, that would indicate the crack were there before they were installed. The crack in the side of the overhead beam is the only one to watch for progression.
Old 04-12-2018, 10:49 PM   #8
jlhaslip's Avatar
Rewards Points: 708
A few ways to minimize the checking are to specify "free of heart" material and also cut a relief cut on the hidden side of the posts.
"Free of Heart" wood can get expensive due to the size of wood required for larger posts/beams.
Nealtw likes this.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Help Replacing a Roof-Overhang Support Post Paultergeist Building & Construction 5 04-06-2017 04:03 PM
Beam build, joint not over post WillK Building & Construction 8 01-03-2012 10:31 AM
Tiling vertical post kellyharris15 Flooring 12 02-22-2011 04:28 PM
Deck Post Height for Composite Post Railing ylwdog Building & Construction 5 11-15-2010 10:01 AM
