Thermal Break At Garage Ramp - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree6Likes
  • 1 Post By jlhaslip
  • 2 Post By Yodaman
  • 2 Post By stadry
  • 1 Post By Yodaman
Old 11-11-2017, 08:47 PM   #1
Knucklez's Avatar
Rewards Points: 1,002
thermal break at garage ramp
designing a new construction detached garage in the frost insulated shallow foundation style. that's 2" thick of XPS wrapping concrete foundation (and below). across the front of the foundation where the garage door will be, how do i make the thermal break to the cement pour ramp?
my working (or not working) idea so far is
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 11-11-2017, 09:50 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: thermal break at garage ramp
A strip of Donacona board would be as good as anything.
Not sure what you would be calling it down there in Onterrible.
About a half inch thick material that has been soaked in asphalt and used as a separation material between slabs.
And tie the ramp to the slab with rebar stubs.
123pugsy likes this.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 11-18-2017, 03:12 PM   #3
Knucklez's Avatar
that's what you do when there is no 2" thick rigid insulation. the R-value of Donacona board is too low and you'd get major heat leakage, hence the need to wrap the foundation with XPS.. i'm in winter environment, so it matters to me.
OK thanks, was wondering about that
Old 12-04-2017, 09:14 PM   #4
Knucklez's Avatar
any suggestions?
Old 12-05-2017, 06:17 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,442
Ayuh,.... Is this a radiant heated slab,..??
Bondo is online now   Reply With Quote
Old 12-05-2017, 06:56 AM   #6
Property Mgt/Maint
Rewards Points: 8,206
I was curious how others have done this as well. I can say that per your sketch, the thin cross section of concrete above the XPS edge looks like a sure problem for cracking and breaking off.
Maybe run the foam all the way to near surface and cover with a strip off deck plate.
Bondo and stadry like this.
Yodaman is offline   Reply With Quote
Old 03-10-2018, 03:27 PM   #7
Knucklez's Avatar
yes sir
Old 03-10-2018, 03:31 PM   #8
Knucklez's Avatar
but i worry for driving over that because its just foam under the plate
Old 03-10-2018, 04:52 PM   #9
Rewards Points: 3,602
then use heavier deck plate,,, btw, this is the same method used on bridge approach slabs in conc hwys - 2" foam
Bondo and Yodaman like this.
Old 03-11-2018, 08:48 AM   #10
Bondo's Avatar
Ayuh,.... Simplest answer is a 6" wide, by 3/16" flat steel plate tap-coned over the foam,....
Old 03-11-2018, 11:49 AM   #11
Property Mgt/Maint
I'd probably set right in the wet concrete while pouring it.
Knucklez likes this.
Old 03-11-2018, 08:18 PM   #12
Bondo's Avatar
Ayuh,.... Even better,.....
Old 05-17-2018, 06:45 PM   #13
Knucklez's Avatar
thanks all for the tips. i can get some steel plate locally so that's cool.
Converted garage to bedroom while garage door still intact. Sealing wall opening. calleros24 Building & Construction 9 11-01-2014 06:00 PM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 10:32 PM
unconditioned garage reillyoevans HVAC 3 08-20-2011 06:29 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-25-2011 11:58 PM
Thermal Break For Tile fierysun Flooring 2 03-06-2008 06:22 PM
