Temporary Kitchen Countertop - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By stick\shift
Old 09-01-2019, 05:03 AM   #1
Rewards Points: 282
I decided last week that I wanted to build new kitchen cabinets. I need a temporary countertop, so I went with what I already had which is 3/4 inch maple plywood. It will be 1 1/2 inches thick once I add some strips of plywood around the bottom edges of the top piece.
I need to seal it with something that is waterproof and food safe. Does anyone have recommendations on what I should use.
Temporary may end up being a few months.
Jamesonc is offline   Reply With Quote
Old 09-01-2019, 05:09 AM   #2
Rewards Points: 4,268
Re: Temporary Kitchen Countertop
Three coats of oil based polyurethane with light, scuff sanding and removal of dust between coats has always been my go-to wood finish. Once cured, poly is food safe.
de-nagorg and Gregsoldtruck79 like this.
stick\shift is offline   Reply With Quote
The Following User Says Thank You to stick\shift For This Useful Post:
Jamesonc (09-01-2019)
Old 09-01-2019, 05:20 AM   #3
Rewards Points: 282
Something else I already have on hand. I'll stop looking at these epoxy coatings, they can get pretty expensive.
I'm actually pretty content with how the plywood countertop looks.
Old 09-01-2019, 11:14 AM   #4
Rewards Points: 158
It's better if you can protect the plywood edge with min wood filler then urethane. Around the sink cut out as well. The edges may not be protected by 3 coats and will absorb some water. For temp use it may be ok but not sure about food safety. You can wipe the counter with vinegar or bleach every few days.
carpdad is offline   Reply With Quote
Old 09-01-2019, 11:34 AM   #5
Hammered Thumb
Rewards Points: 288
I once did that because we had a party before part of the kitchen was done. I wrapped the plywood with a plastic tablecloth cover. It worked for a few weeks, but it wasn't near the sink or stove.
3onthetree is offline   Reply With Quote
Old 09-03-2019, 05:00 PM   #6
Rewards Points: 1,436
Had a basic plywood countertop, couple of coats of poly, in my kitchen laying over a couple of tall sawhorses for nearly a year before I got around to real cabinets for the house. Wife didn’t exactly love it.....but nothing happened to it and no one died. Ron
ront02769 is offline   Reply With Quote
The Following User Says Thank You to ront02769 For This Useful Post:
Jamesonc (09-09-2019)
Tags
countertop , food safe , kitchen , waterproof
