Temp. Unload Exterior Supporting Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-28-2009, 04:16 PM   #1
Temp. unload exterior supporting wall
I want to remove an existing first-floor window and replace with longer one. The wall runs parallel to the floor joists above. How does one support the floor rimjoist (and roof-supporting wall above) while adding a longer header to the wall below?
mdeanp is offline   Reply With Quote
Old 11-28-2009, 10:16 PM   #2
You can attach a 2x10 or 2x12 to the studs just below the ceiling over the window opening. Make this extend beyond the rough opening of the window that you are wanting to install. Once you have the 2x12 anchored to the studs it will create a ledger that will be a temproary header until you are able to install the new header. You will want to install braces coming down to transfer the weight to the floor. this should hold the weight until you are able to install the new header. Good luck
RobQuillin is offline   Reply With Quote
Old 11-28-2009, 11:13 PM   #3
Registered User
Rewards Points: 526
Remember that the floor joists below are probably run the same direction. So if you add supports to hold anything up, be sure to lay a 3' 4x4 down under each, across the joists first or the load could punch through the ply decking. Unless on a slab.....
If header height interferes with Rob's ledger, I would cut the ceiling drywall back to the first joist above, next to. Install temp braces every 2' under the sub-floor alongside the rim joist, down at an angle onto the 4x4's , sprung in tight, the new headers length. Add a nailer at the joist after adding header and two trimmers each side. If any point loads above the new opening (window trimmers, posts, etc.), I would use a 4x4 or 4x6 block between stud bays on the bottom plate to distribute the load on that or both sides. Unless you can get at the floor from below to add a point load block vertically to the mud-sill.
This may help you: http://www.burlington.org/Building08/Spans.pdf
Be safe, Gary
Drain tile questions for retaining wall installation. Tmaxx1 Landscaping & Lawn Care 11 06-10-2011 11:17 AM
Temp. Wall MDT Carpentry 5 07-25-2009 01:15 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 03:29 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
