Tar Paper Torn On Side Of House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-10-2015, 01:44 PM   #1
Rewards Points: 28
Question
Tar paper torn on side of house
So in the process of remodeling my bathroom I opened the inside walls and found a nail and a wood dowel had came thru and tore the tar paper from the outside. There is no evidence of holes outside or any leakage inside the wall. There is a gutter downspout that is suspect but the clamp is not accessible to see for sure. I call the gutter guy and he said it is fine to nail thru the stucco into the tar paper. ?? I cut the nail end off and the wooden dowel. Enough of the back round. I need to seal this barrier. I t seems that breaking the outside stucco to repair the paper seems extreme. I am planning to try and slip some paper on the outside wall side against the stucco and use some tar type adhesive to glue it there. Then I thought maybe some of that heavy tar type tape over that. I read about the polyurethane spray insulation making a moisture seal, but can not get any clarity on that. Any ideas or methods to perform these task are very much appreciated.
Jwhitman is offline   Reply With Quote
Old 06-10-2015, 01:50 PM   #2
Rewards Points: 144
A larger picture from further back may help.I have never hear of anyone using dowels for construction.
mako1 is offline   Reply With Quote
The Following 2 Users Say Thank You to mako1 For This Useful Post:
gregzoll (06-10-2015), Jwhitman (06-11-2015)
Old 06-10-2015, 10:05 PM   #3
Rewards Points: 18,118
It's not a big deal, just put some house wrap tape over the hole.
Old 06-10-2015, 10:40 PM   #4
Rewards Points: 4,796
You have no plywood sheathing.?
ron45 is offline   Reply With Quote
The Following User Says Thank You to ron45 For This Useful Post:
Old 06-11-2015, 01:09 PM   #5
Rewards Points: 28
No plywood sheathing just stucco outside tar paper and inside wall shown.
Old 06-12-2015, 12:48 AM   #6
Registered User
Rewards Points: 526
Just add some tar paper there, cut a horizontal slit in existing paper at the hole, slip paper in/down on other side, up on inside to drain any liquid water. NO glue to stucco as the paper should be two layers; one for bond break (next to stucco) and other- WRB- next to studs. http://www.buildingscience.com/docum...ong-from-start
Gary
PS. Welcome to the forums!
Old 06-12-2015, 01:11 AM   #7
Rewards Points: 28
I really wish I fully understand how making a bigger hole makes a better seal. Do you have any pictures so I can understand how to do it. I only have access to the inside of the house. I really want to do it right I just don't understand how to slip the repair piece in.
Thanks for the help
Old 06-15-2015, 03:01 AM   #8
Just make slits into the paper so it will rest around the dowel and tape it.
Side of house, under siding joetab24 Concrete, Stone & Masonry 10 07-11-2014 03:56 PM
SER cable through side of the house using LB seephor Electrical 22 04-04-2014 08:44 PM
Extending gutter across side of house or downspout? ddurlach Roofing/Siding 5 02-22-2013 04:37 PM
Attaching wood fence to house TheCowGod Building & Construction 5 04-13-2012 04:57 PM
Conduit up side of house PhillyRyan Electrical 3 08-19-2010 01:47 PM
