Tapcons - Maximum Embedment Depth - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-08-2016, 04:05 PM   #1
Rewards Points: 126
Tapcons - maximum embedment depth
Why do tapcons have an enbedment range? What is the negative effect of using a tapcon which is too long and exceeds the recommended 1-3/4" maximum embedment?
garrett1812 is offline   Reply With Quote
Old 04-08-2016, 04:08 PM   #2
Rewards Points: 18,506
Re: Tapcons - maximum embedment depth
There is none, the main concern is not deep enough.
Old 04-08-2016, 04:13 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 618
Ayuh,.... Ya wear out more drill bits drillin' holes deeper than necessary,....
At some point, the friction from drivin' the tap-con reaches the point where the head snaps off,....
More excessive depth does Nothin' for Strength,....
That's 3 reasons off the top of my head,.....
The Following User Says Thank You to Bondo For This Useful Post:
Colbyt (04-09-2016)
Old 04-08-2016, 04:14 PM   #4
Rewards Points: 126
Thanks. Although its a bit of a waste, I want to avoid a trip to the store before finishing a project. I have some tapcons about an inch longer than needed.
Old 04-09-2016, 09:10 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 10,256
If the hole isn't right, running long tapcons in usually means that they snap off while being driven in.
Make sure you blow the hole out and they are clean all the way down.
Old 04-09-2016, 12:52 PM   #6
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,592
I tried over length screws this week and they snapped off as mentioned above.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Old 04-09-2016, 03:16 PM   #7
firehawkmph's Avatar
Rewards Points: 2,558
When drilling tapcons, make sure the hole is at least 1/4" deeper than the fastener. Also blow or vac out the dust from the hole. Depends what you are drilling into. They go into modern block units easier than old concrete. Sometimes it's easier to make the extra trip and save some cussing. Once the cussing starts, you're going to make the trip anyway.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 04-09-2016, 09:27 PM   #8
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,578
joe is right about the tapcons,, ive never really had much luck with them, ive found that they dont really provide much holding power other than lateral resistance for bottom plates on concrete.. based on the cost of them alone a roll of tie wire and some hand spikes hold just as well if not better in some situations if its a structural connection i switch to concrete wedge anchors
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Windows on Wash (04-10-2016)
Old 04-09-2016, 09:52 PM   #9
Rewards Points: 126
I hope they work well. I used some today to wall mount a utility sink!
Winder stair tread depth at 12" walk line - code question PostNBeam Building & Construction 9 02-11-2015 08:24 PM
Maximum time to apply next coat Homerepairguy Painting 8 09-26-2014 02:49 AM
What is the maximum depth below grade for termite activity? iLikeDirt Pest Control 4 08-02-2014 07:18 PM
Will these stairs pass IBC code? jonrya91 Building & Construction 21 11-02-2012 08:26 AM
Tapcons jamiedolan Building & Construction 10 08-16-2009 08:36 AM
