Sweating Walls. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-16-2010, 03:50 PM   #1
Sweating walls.
How do I fix them?
Joe Ann is offline   Reply With Quote
Old 08-16-2010, 04:36 PM   #2
Electrician
Proby's Avatar
A lot more information is needed.
I personally had my walls sweat after I sealed up my house. Some areas would sweat in the middle of Winter, when I opened the walls up I found that those areas were missing insulation.
The problem was that I sealed my house so well that the humidity was not able to escape. Even using a good bathroom exhaust fan didn't help because it wasn't able to pull in makeup air. My windows and some parts of my walls would be dripping with water in the morning after a cold night.
I fixed this by simply leaving two windows cracked opened at all times, this was enough to fix the humidity issue and allow to bathroom fan to remove the humid air after a shower and replace it with dryer air.
Since it's Summer, I assume you are having a different problem, unless you are located in the North Pole, which you might be since you didn't fill out your location.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
Installing Plumbing in 2Ē Wide Walls? Robert1_1 Plumbing 5 09-16-2009 08:43 AM
bowing walls - repair? elementx440 Building & Construction 26 03-04-2009 03:07 PM
Moisture on walls chrisr Building & Construction 1 01-20-2008 09:37 AM
