Supporting Hip Roof For Gazebo - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-12-2015, 05:15 PM   #1
Rewards Points: 4
Supporting hip roof for Gazebo
Good day! First post. DIYer that tries things he shouldn't. I'll attempt to describe my project below - but honestly do not know much construction-speak. It's complicated trying to explain this.
I am building a 12' x 20' gazebo and have settled on an uncommon design for the roof that I pray is going to work. It made sense when drawing it up.
I have 2 8x8s already set 5' from the ends and centered as far as width. The rest of the deck is supported by 4x4s on bases on concrete. 2x10s are bolted on either side of the 8x8s running the length. Joists are 16" oc. Only thing left for the deck is screw down the boards.
The plan is to have the entire roof supported by the 8x8s (there are no other posts above deck line). Here's a terrible drawing
(Peaks should all be over 8x8s here, not offset)
- 2x10 ridge beam seated down in notch across top of 8x8s (10' across)
- 12' 2x10s on either side of 8s running the width. 4-bolt pattern through steal plates to avoid teetering.
- 45 angle 4x6s running up from 8x8s through the 2x10s (bolted to them) for lateral support.
- 20' 4x6s fastened ontop of the four 2x10s supporting length of roof.
- 12' 4x6s on either end (bolted to ends of 20') supporting roof.
- Lastly I'm considering adding additional 45 angled supports coming off the 8x8s downward to add another triangle for lateral support. Haven't settled on size yet. (See pic showing end)
I'm getting some grief from the lumber provider about the 8x8s supporting all of this weight. I figured as a last resort I could swap out the deck's short 4x4 corners with ones that extend to the roof corners.
Thoughts?
Natedlee is offline   Reply With Quote
Old 06-12-2015, 07:41 PM   #2
Rewards Points: 454
I think I would at least use 6x6's rather than 4x4 ,
scottktmrider is offline   Reply With Quote
Old 06-12-2015, 09:45 PM   #3
Rewards Points: 4
Do you mean if I choose to extend corners deck support posts all the way to the roof corners? I've thought about this, but if I believe the initial plan is "good enough" and I'm only adding support for the sake of peace of mind, it would seem 4x4s provide that. Now if I'm kidding myself and there's no way the original plan is safe then I'd agree 6x6s would be the way to go. Problem is I'd have to rip apart the ends of my deck. (As you can see the deck is actually wider than 12'. We just decided to use the full extent of the 16' 2x10s I got vs trimming them back. We only intend to cover the original perimeter with the roof.)
Old 06-13-2015, 11:39 AM   #4
Rewards Points: 1,910
One good wind will flip that thing right over.
The Following User Says Thank You to jogr For This Useful Post:
hand drive (06-13-2015)
Old 06-13-2015, 11:47 AM   #5
AHH, SPANS!!!
Rewards Points: 1,166
that is way to much cantilever past the posts. 4' either direction would probably be about the max for that design without some serious fabricated metal plates but even then the posts could turn and buckle just from the force of the roof.
hand drive is offline   Reply With Quote
Old 06-13-2015, 02:04 PM   #6
Rewards Points: 454
As hand drive said that's a lot of weigh to overhang, I just hate 4x4 they twist and curl so bad if there sticking up like that
rerplace roof on 200 year old house newroof Roofing/Siding 7 11-24-2013 06:23 PM
rubber roof over tar & thoughts on quote wfmrules3 Roofing/Siding 13 10-16-2011 10:00 PM
Flat roof and insulation quandry paredown Roofing/Siding 2 08-21-2010 12:50 AM
Tying new roof into old. Clutchcargo Roofing/Siding 15 11-07-2009 06:48 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
